Inleiding
It is crucial to replace your back-up and brake lights immediately because it will affect road safety when you are stopping the car or having an emergency stop. Notice that the police also may pull you over if your tail light is not working.
Are the back-up or brake lights not working in your Hyundai Veloster? Don’t want to spend money on the replacement to the auto store? Save money and do it yourself at home or in your garage following this guide step by step. It is easy to understand and follow even you are a beginner.
In this guide, I will replace the back-up light and brake light for a 2012 Hyundai Veloster.
Brake and tail light bulb type: P28/8W (Wattage: 28/8 )
Back-up light bulb type: W16W (Wattage: 16)
Note: You can wear your safety & work gloves before working on the replacement.
Wat je nodig hebt
Open the trunk first.
Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
