Ga door naar hoofdinhoud
2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement
Wat je nodig hebt
  1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: stap 1, afbeelding 1 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: stap 1, afbeelding 2 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: stap 1, afbeelding 3 van 3
    • Make sure the car is off before you start your replacement. However, You don't have to disconnect the car battery.
    • Open the trunk first.
    • Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
  2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 2, afbeelding 1 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 2, afbeelding 2 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 2, afbeelding 3 van 3
    • Using both hands, carefully pull the brake & tail light off.
  3. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 3, afbeelding 1 van 1
    • Here is the tail light assembly.
    • The left one is for the brake light.
    • The right one is for the back-up light.
  4. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 4, afbeelding 1 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 4, afbeelding 2 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 4, afbeelding 3 van 3
    • Twist and turn the backup light to the right. And then pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the light bulb easily.
  5. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 5, afbeelding 1 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 5, afbeelding 2 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 5, afbeelding 3 van 3
    • Twist and turn the brake light to the right and pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the bulb easily.
  6. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 6, afbeelding 1 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 6, afbeelding 2 van 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: stap 6, afbeelding 3 van 3
    • Replace the light bulbs.
    • Check that the light bulbs work first before replacing 10 mm screws.
Conclusie
Adrian Ng
196 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 98
Altijd: 4,240
