Ga door naar hoofdinhoud
2011-2017 Hyundai Accent Brake Light Replacement
  1. 2011-2017 Hyundai Accent Brake Light Replacement, Brake Light: stap 1, afbeelding 1 van 1
    • Open the trunk of the vehicle.
  2. 2011-2017 Hyundai Accent Brake Light Replacement: stap 2, afbeelding 1 van 3 2011-2017 Hyundai Accent Brake Light Replacement: stap 2, afbeelding 2 van 3 2011-2017 Hyundai Accent Brake Light Replacement: stap 2, afbeelding 3 van 3
    • View the side flap for whichever side has the dead bulb. (This is the left side view.)
    • Pull the flap up and locate the brake light.
    • The flap may need some extra force to open because the cutouts are typically not cut all the way through.
  3. 2011-2017 Hyundai Accent Brake Light Replacement: stap 3, afbeelding 1 van 2 2011-2017 Hyundai Accent Brake Light Replacement: stap 3, afbeelding 2 van 2
    • Twist the socket counterclockwise to gain access to the brake light.
  4. 2011-2017 Hyundai Accent Brake Light Replacement: stap 4, afbeelding 1 van 2 2011-2017 Hyundai Accent Brake Light Replacement: stap 4, afbeelding 2 van 2
    • Push down slightly and twist the bulb counterclockwise to remove the dead bulb.
    • Pay attention to the protrusions located on the bottom of the bulb. You will need to align these protrusions with the socket when inserting the new bulb.
  5. 2011-2017 Hyundai Accent Brake Light Replacement: stap 5, afbeelding 1 van 2 2011-2017 Hyundai Accent Brake Light Replacement: stap 5, afbeelding 2 van 2
    • Insert the new bulb into the socket and twist the bulb clockwise to secure it into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
When I followed the instructions in reverse order as instructed to reassemble everything, I ended up with the old bulb back in the vehicle. Is there any way to fix this?
The Other Guy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 60
Afgelopen 30 dagen: 295
Altijd: 14,177
