Ga door naar hoofdinhoud
2011-2018 VW Jetta Oil & Filter Replacement
Wat je nodig hebt
  1. 2011-2018 VW Jetta Oil & Filter Replacement, Prepare Car Jack: stap 1, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare Car Jack: stap 1, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare Car Jack: stap 1, afbeelding 3 van 3
    • Ensure car jack is ready by rotating handle clockwise completely
    • Locate metal beam under car used for jacking
    • Position car jack platform under metal beam
  2. 2011-2018 VW Jetta Oil & Filter Replacement, Raise up passenger side of car: stap 2, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Raise up passenger side of car: stap 2, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Raise up passenger side of car: stap 2, afbeelding 3 van 3
    • Pump car jack handle to raise up car
    • Raise up car stand 4 notches
    • Place car stand underneath wheel metal beam
  3. 2011-2018 VW Jetta Oil & Filter Replacement, Lower car onto car stand: stap 3, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Lower car onto car stand: stap 3, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Lower car onto car stand: stap 3, afbeelding 3 van 3
    • Lower car onto the stands by rotating the jack handle counter-clockwise (very gently)
    • Depending on your model of jack, the jack may lower rapidly or slowly. Do your best to lower the car gently
    • Repeat steps 1-3 on driver side of car
    • At this point, both sides should be raised off the ground
    • Place clean cardboard underneath the car
  4. 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to drain the oil: stap 4, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to drain the oil: stap 4, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to drain the oil: stap 4, afbeelding 3 van 3
    • Locate the oil container underneath the car (this will require crawling under the car and laying on your back
    • Locate the bolt used to drain the oil
    • Position the oil drip pan underneath the bolt
  5. 2011-2018 VW Jetta Oil & Filter Replacement, Drain the oil: stap 5, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Drain the oil: stap 5, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Drain the oil: stap 5, afbeelding 3 van 3
    • Loosen the bolt by turning the 5/16 allen wrench counter-clockwise
    • It may take a significant amount of force to loosen the bolt
    • Once loose, remove the bolt by hand
    • Once the bolt is removed, oil will immediately flow out
    • Make sure the oil drip pan is positioned well
    • Once the bolt is removed, you will get a significant amount of oil on your hand
    • Don't drop the bolt into the oil pan. It will be slippery!
    • Wait ~10 minutes for all the oil to drain out
  6. 2011-2018 VW Jetta Oil & Filter Replacement, Replace oil bolt: stap 6, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Replace oil bolt: stap 6, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Replace oil bolt: stap 6, afbeelding 3 van 3
    • Clean up the drainage hole with paper towel
    • You may need to use a paper towel to wipe up any beading oil
    • Insert the bolt, turning clockwise
    • Tighten the bolt with the 5/16 allen wrench until the wrench won't turn any further. This is plenty tight.
  7. 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to remove oil filter: stap 7, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to remove oil filter: stap 7, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to remove oil filter: stap 7, afbeelding 3 van 3
    • Position drip pan underneath the plastic cover as shown in picture
    • Open the hood of the car
    • Locate the oil filter
    • The oil filter is near the front of the car
    • The oil filter looks like a cylinder
    • Loosen the oil filter by hand
    • It may take a significant amount of force to loosen the oil filer
    • A filter wrench can be used to help loosen the filter
    • Turn the filter clockwise to loosen (from the perspective of the user) - see video if you're confused
    • Remove oil filter
    • Once you remove the filter, some remaining oil will spill out, onto your hand, and into your well placed oil drip pan
    • The filter may be very slippery, don't drop it!
  8. 2011-2018 VW Jetta Oil & Filter Replacement, Drain the Oil Filter: stap 9, afbeelding 1 van 2 2011-2018 VW Jetta Oil & Filter Replacement, Drain the Oil Filter: stap 9, afbeelding 2 van 2
    • Place old oil filter upside down on the knob in the oil drip pan
    • Get new oil filter
    • Install oil filter
    • Turn the oil filter counter clockwise to install (as appears to the user)
    • Tighten by hand until both hands can't get it any tighter - This is plenty tight
    • Wipe up the oil that spilled out when you replaced the filter
    • This spilled oil is normal
    • Use plenty of paper towel
  9. 2011-2018 VW Jetta Oil & Filter Replacement, Clean up any spilled oil pt. 2: stap 12, afbeelding 1 van 2 2011-2018 VW Jetta Oil & Filter Replacement, Clean up any spilled oil pt. 2: stap 12, afbeelding 2 van 2
    • Wipe up any oil that spilled below the filter
  10. 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to put in new oil: stap 13, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to put in new oil: stap 13, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Prepare to put in new oil: stap 13, afbeelding 3 van 3
    • Locate the oil cap
    • Remove the oil cap
    • Place funnel into oil cavity
    • Pour in new oil
    • Engine oil is sold in 5 litre containers. VW engines only require ~4 litres. Only pour in 4/5 of the oil!
  11. 2011-2018 VW Jetta Oil & Filter Replacement, Clean Oil Dipstick: stap 15, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Clean Oil Dipstick: stap 15, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Clean Oil Dipstick: stap 15, afbeelding 3 van 3
    • Remove oil dipstick
    • Clean oil dipstick with paper towel
    • Insert oil dipstick all the way
  12. 2011-2018 VW Jetta Oil & Filter Replacement, Check Oil Level: stap 16, afbeelding 1 van 2 2011-2018 VW Jetta Oil & Filter Replacement, Check Oil Level: stap 16, afbeelding 2 van 2
    • Check Oil Level
    • If oil is too low, add more
    • Oil is full when the level is just below the bend in the metal of the dipstick
  13. 2011-2018 VW Jetta Oil & Filter Replacement, Put away old oil filter: stap 17, afbeelding 1 van 2 2011-2018 VW Jetta Oil & Filter Replacement, Put away old oil filter: stap 17, afbeelding 2 van 2
    • Empty any remaining oil in the filter into the oil drip pan
    • Turn the oil filter upside down and place into the box of the filter that was just installed into the car
    • Mark the filter box as "old"
    • Return the filter to a mechanic shop for recycling
  14. 2011-2018 VW Jetta Oil & Filter Replacement, Remove the car stands: stap 18, afbeelding 1 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Remove the car stands: stap 18, afbeelding 2 van 3 2011-2018 VW Jetta Oil & Filter Replacement, Remove the car stands: stap 18, afbeelding 3 van 3
    • Prepare car jack by turning the handle clockwise all the way
    • Pump the car jack and position the jack underneath the metal beam
    • Continue pumping the jack, raising the car off the car stands
    • Remove the car stand
  15. 2011-2018 VW Jetta Oil & Filter Replacement, Lower car onto the ground: stap 19, afbeelding 1 van 1
    • Lower the individual car side onto the ground by turning the handle of the car jack counter-clockwise
    • Rotate clockwise as gently as possible
    • Repeat step 18 and 19 for the other side of the car
    • Turn on car
    • Leave car running for 5 minutes to let oil circulate
    • After 5 minutes, check oil level using the dipstick
    • If oil level has dropped, add more oil - this is normal,
  16. 2011-2018 VW Jetta Oil & Filter Replacement, Pour dirty oil into empty container: stap 21, afbeelding 1 van 2 2011-2018 VW Jetta Oil & Filter Replacement, Pour dirty oil into empty container: stap 21, afbeelding 2 van 2
    • Place funnel into oil container
    • If there is left-over clean oil, you can pour the clean oil into a second container of clean oil - this avoids waste
    • If you don't care about the remaining 1/5 of clean oil, just mix the dirty oil with the clean oil
    • Pour the old oil into the recently-emptied oil container
    • Be careful not to spill any oil on the ground
    • Mark the oil container as "old" and return to a mechanic shop for recycling
Conclusie
Drive off into the sunset
Enjoy a cool beverage (but not while driving off into the sunset)
3 andere personen hebben deze handleiding voltooid.
Benjamin Gee
929 Reputatie
5 handleidingen geschreven
Baylor, Team 4-5, Williams Spring 2015 Lid van Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Leden
11 handleidingen geschreven
2 opmerkingen
Excellent guide, very well explained.
Just a comment; I have a 2017 VW Jetta, it is a 2.5 with 5 cylinders and it needs more motor oil than stated.
Cristian Giner - Antwoord
Great guide, thanks so much! The oil pan bolt on my 2016 Jetta SE was 19mm but everything else was exactly as described
evergreen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 136
Afgelopen 30 dagen: 592
Altijd: 17,980
