Ga door naar hoofdinhoud
2010 Jeep Liberty Headlight Bulb Replacement
Wat je nodig hebt
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 1 van 1
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: stap 2, afbeelding 1 van 3 2010 Jeep Liberty Headlight Bulb Replacement: stap 2, afbeelding 2 van 3 2010 Jeep Liberty Headlight Bulb Replacement: stap 2, afbeelding 3 van 3
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: stap 3, afbeelding 1 van 3 2010 Jeep Liberty Headlight Bulb Replacement: stap 3, afbeelding 2 van 3 2010 Jeep Liberty Headlight Bulb Replacement: stap 3, afbeelding 3 van 3
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: stap 4, afbeelding 1 van 1
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Conclusie
Congratulations! You have a shiny new headlight.
8 andere personen hebben deze handleiding voltooid.
Ryan Griffin
245 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 76
Altijd: 9,465
