Ga door naar hoofdinhoud
2010-2014 Ford Mustang Reverse Light Bulb Replacement
Wat je nodig hebt
  1. 2010-2014 Ford Mustang Reverse Light Bulb Replacement, Reverse Light Bulb: stap 1, afbeelding 1 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement, Reverse Light Bulb: stap 1, afbeelding 2 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement, Reverse Light Bulb: stap 1, afbeelding 3 van 3
    • Open the trunk by either pushing the button to the left of the gear selector, or clicking the button twice on the keyfob.
    • Open the trunk.
  2. 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 2, afbeelding 1 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 2, afbeelding 2 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 2, afbeelding 3 van 3
    • Remove the plastic trim inside the trunk by unscrewing the top plastic retainers by hand (1 on each side).
    • Pull the bottom plastic retainers out with your hand (1 on each side).
    • If you are having trouble with the bottom retainer, you can use a flathead screwdriver to pry it out.
    • Replace the bottom retainers with new ones when reassembling.
    • To remove the plastic trim, simply pull it up and out.
  3. 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 3, afbeelding 1 van 2 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 3, afbeelding 2 van 2
    • Although these connectors are shock resistant, you should disconnect the battery to be safe.
    • Unplug the tail light from the wiring harness by simultaneously pressing and holding the clip on the top of the harness and pulling apart.
  4. 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 4, afbeelding 1 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 4, afbeelding 2 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 4, afbeelding 3 van 3
    • Use the 11 mm socket and socket wrench to remove the nuts from the 3 bolts.
    • Remove tail light assembly.
  5. 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 5, afbeelding 1 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 5, afbeelding 2 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 5, afbeelding 3 van 3
    • Twist the reverse light bracket 90 degrees to the left, and pull the light bulb assembly out.
    • Pull the burnt out light bulb out of the socket.
  6. 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 6, afbeelding 1 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 6, afbeelding 2 van 3 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 6, afbeelding 3 van 3
    • Push the new light bulb into the socket.
    • Twist the light bulb assembly 90 degrees to the right to reinsert the light bulb assembly into the slot.
  7. 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 7, afbeelding 1 van 2 2010-2014 Ford Mustang Reverse Light Bulb Replacement: stap 7, afbeelding 2 van 2
    • To reattach the taillight to the wiring harness, do the reverse of step 4.
    • If you disconnected the battery in step 4, make sure to reattach it before testing.
    • Turn the car on, press the brake, and put it in reverse to test the reverse light.
    • Make sure to engage the parking brake before getting out to look at the taillight.
    • If the light turns on, continue to the conclusion.
    • If the light does not turn on, repeat steps 3, 5, and 6 to make sure the bulb is inserted correctly.
Conclusie
To reassemble your device, follow these instructions in reverse order from step 5.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
THANK YOU!! This worked Great and Thank Goodness you listed the Replacement Bulb Number 912, because none of the local auto parts store knew they had matching LED bulbs. They all had weird unknown unavailable halogen replacements. Duh. Works Great Now!! Thanks Much!! :-D Jeeeeeeeeeeeeeeeeeeeeeeeeeeeeeem :)
James Kohl - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 63
Altijd: 2,846
