Ga door naar hoofdinhoud
2010-2014 Ford Mustang Air Filter Replacement
  1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: stap 1, afbeelding 1 van 2 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: stap 1, afbeelding 2 van 2
    • Make sure the vehicle is off before proceeding. Working under the cars hood can lead to burns if the car is still hot. Be careful!
    • Open the hood by pulling on the lever by the driver's feet.
    • Push upward on the latch under the center of the hood to unlock it.
  2. 2010-2014 Ford Mustang Air Filter Replacement: stap 2, afbeelding 1 van 1
    • Locate the Air Box
  3. 2010-2014 Ford Mustang Air Filter Replacement: stap 3, afbeelding 1 van 3 2010-2014 Ford Mustang Air Filter Replacement: stap 3, afbeelding 2 van 3 2010-2014 Ford Mustang Air Filter Replacement: stap 3, afbeelding 3 van 3
    • Locate the two latches that keep the air box closed.
    • Push on the latch to open the air box as shown in the picture, and repeat on the second latch.
    • Pull up on the top part of the air box and push it to the front of the car to open.
  4. 2010-2014 Ford Mustang Air Filter Replacement: stap 4, afbeelding 1 van 2 2010-2014 Ford Mustang Air Filter Replacement: stap 4, afbeelding 2 van 2
    • Make note of the orientation of the air filter before removing it.
    • Lift the filter straight up from the triangle corner and remove it.
  5. 2010-2014 Ford Mustang Air Filter Replacement: stap 5, afbeelding 1 van 2 2010-2014 Ford Mustang Air Filter Replacement: stap 5, afbeelding 2 van 2
    • Inspect for debris and dirt.
    • The first filter is dirty but does not need to be cleaned or replaced yet.
    • The second filter is dirty and does need to be cleaned or replaced
    • Do not discard the filter because it may be covered under a warranty.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Christopher Pell
251 Reputatie
5 handleidingen geschreven
Cal Poly, Team 15-45, Forte Fall 2012 Lid van Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 77
Altijd: 4,271
