Ga door naar hoofdinhoud
2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement
Wat je nodig hebt
    1. 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement, Center Dome Light Bulb: stap 1, afbeelding 1 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement, Center Dome Light Bulb: stap 1, afbeelding 2 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement, Center Dome Light Bulb: stap 1, afbeelding 3 van 3
      • Pry the assembly dome light using a spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 2, afbeelding 1 van 1
      • Using two fingers, pinch and pull the dome light assembly downward until it's hanging.
      Vraag FixBot
      Voeg opmerking toe
    3. 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 3, afbeelding 1 van 2 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 3, afbeelding 2 van 2
      • Use your hand to grab and pull down the assembly. Be sure to pull each side of the assembly after the other.
      Vraag FixBot
      Voeg opmerking toe
    4. 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 4, afbeelding 1 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 4, afbeelding 2 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 4, afbeelding 3 van 3
      • Pinch the LED bulb with 2 fingers.
      • Pull downward until the LED comes out.
      Vraag FixBot
      Voeg opmerking toe
    5. 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 5, afbeelding 1 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 5, afbeelding 2 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 5, afbeelding 3 van 3
      • Insert the replacement bulb into the housing.
      • Push the bulb upwards with your thumb until it pops inside
      • If replacing with LED (T10), be sure to test the bulb while you still have the assembly out as LED bulbs are typically directional, which, if installed in the wrong direction, may result in a non-powered bulb.
      Vraag FixBot
      Voeg opmerking toe
    6. 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 6, afbeelding 1 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 6, afbeelding 2 van 3 2010-2015 Chevrolet Camaro Center Dome Light Bulb Replacement: stap 6, afbeelding 3 van 3
      • Reinsert the dome light assembly.
      • Press around the edges until the clicking sound stops.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Now turn on your engine and dome light to see if your replacement bulb is properly inserted. Your light should be as good as new!
HeverR
163 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-2, Harris Spring 2026 Lid van CSU Los Angeles, Team 5-2, Harris Spring 2026
CSULA-HARRIS-S26S5G2
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 50
Altijd: 245
