Ga door naar hoofdinhoud
2010-2017 Suzuki Swift Engine Air Filter Replacement
Wat je nodig hebt
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: stap 1, afbeelding 1 van 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: stap 1, afbeelding 2 van 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: stap 1, afbeelding 3 van 3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: stap 2, afbeelding 1 van 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: stap 2, afbeelding 2 van 2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: stap 3, afbeelding 1 van 1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: stap 4, afbeelding 1 van 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: stap 4, afbeelding 2 van 2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
knipwim
8.527 Reputatie
30 handleidingen geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 127
Altijd: 6,357
