Ga door naar hoofdinhoud
2009-2012 Toyota Corolla Cabin Air Filter Replacement
Wat je nodig hebt
  1. 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 1 van 2 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 2 van 2
    • Get into the front passenger seat and open the lower glovebox.
  2. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 2, afbeelding 1 van 2 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 2, afbeelding 2 van 2
    • Push the two side walls of the glovebox towards the center to free the stopper peg on each side.
  3. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 3, afbeelding 1 van 1
    • Move to the right side of the glovebox and gently pop off the black retaining arm.
  4. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 4, afbeelding 1 van 1
    • Gently lower the glovebox to the floor. It should hang in the position shown.
  5. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 5, afbeelding 1 van 3 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 5, afbeelding 2 van 3 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 5, afbeelding 3 van 3
    • Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away.
  6. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: stap 6, afbeelding 1 van 1
    • Pull the old cabin air filter out of the housing.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Some filters will have an arrow stating to point arrow up, while others will have the arrow go in the direction of the airflow, which would be down. Install new filter accordingly.
Eindstreep
30 andere personen hebben deze handleiding voltooid.
Geoff Wacker
89.934 Reputatie
89 handleidingen geschreven
8 opmerkingen
This is great! Thank you so much :) Saved $80
Erik Phillips - Antwoord
The direction of airflow is definitely from top to bottom. I stuck a piece of paper in while the cabin filter was out with fan running, it pulled the paper downward. Be careful not to let the paper go too low because it will hit the fan just a couple inches below the filter compartment.
tom.mcgathen - Antwoord
Very useful. TY
Virgil Caine - Antwoord
There is another air filter above this one. Anyone know how to remove it so it can be cleaned or replaced?
Wayne - Antwoord
I’m an 85 year old widow and I can follow these detailed instructions. Thank you very much.
Frances Pearce - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 353
Altijd: 59,803
