Ga door naar hoofdinhoud
2009-2014 Hyundai Sonata Cabin Air filter Replacement
  1. 2009-2014 Hyundai Sonata Cabin Air filter Replacement, Cabin Air filter Replacement  for. Hyundai Sonata: stap 1, afbeelding 1 van 1
    • Go to the passenger side of the car and sit in the passenger seat. Pull the glove box down using the lever.
  2. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 2, afbeelding 1 van 1
    • On the right side of the love box will be a plastic hydraulic; push the two pieces of plastic of the part sticking out towards each other. This should release the glove box on this side.
  3. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 3, afbeelding 1 van 1
    • Then on the top left, there is a plastic screw; unscrew it and be mindful that when this happens, the glove box will swing down.
  4. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 4, afbeelding 1 van 1
    • This is what the screw should look like after you take it out.
  5. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 5, afbeelding 1 van 1
    • This is what will be behind the glove box.
  6. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 6, afbeelding 1 van 1
    • On the right side there should be a clamp and push the two ends against each other and pull towards you.
  7. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 7, afbeelding 1 van 1
    • This is the clamp mentioned in the previous step.
  8. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: stap 8, afbeelding 1 van 1
    • Then just pull the cover to the right to slide it out. Then you can access the air filter and change it from here.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brandon Pollaccia
217 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 92
Altijd: 387
