Inleiding
So, you happened to pull on the grab handle hard enough for it to come loose, or maybe there has been some damage to where you need to replace it. Then when hitting a wide turn you reach for the handle to brace yourself only to be reminded that it isn't there anymore. Well, brace yourself for a simple repair/replacement process so that you can brace yourself when hitting that bend. This is a step-by-step guide on how to replace and/or install your grab handle on a 2009-2015 Toyota Prius.
Wat je nodig hebt
Bijna klaar!
Eindstreep
