Ga door naar hoofdinhoud
2008 Toyota Corolla Battery Replacement
Wat je nodig hebt
  1. 2008 Toyota Corolla Battery Replacement, Battery: stap 1, afbeelding 1 van 2 2008 Toyota Corolla Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: stap 2, afbeelding 1 van 2 2008 Toyota Corolla Battery Replacement: stap 2, afbeelding 2 van 2
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: stap 3, afbeelding 1 van 2 2008 Toyota Corolla Battery Replacement: stap 3, afbeelding 2 van 2
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: stap 4, afbeelding 1 van 3 2008 Toyota Corolla Battery Replacement: stap 4, afbeelding 2 van 3 2008 Toyota Corolla Battery Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: stap 5, afbeelding 1 van 3 2008 Toyota Corolla Battery Replacement: stap 5, afbeelding 2 van 3 2008 Toyota Corolla Battery Replacement: stap 5, afbeelding 3 van 3
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: stap 6, afbeelding 1 van 1
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Lair Noriega
237 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 97
Afgelopen 30 dagen: 207
Altijd: 5,254
