Ga door naar hoofdinhoud
2008 Honda Pilot Tail Light Assembly Replacement
Wat je nodig hebt
  1. 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: stap 1, afbeelding 1 van 2 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: stap 1, afbeelding 2 van 2
    • Open the vehicle's trunk to see the two bolts holding the assembly to the body.
    • Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
    • Save the bolts! They will be needed for installing the new assembly.
  2. 2008 Honda Pilot Tail Light Assembly Replacement: stap 2, afbeelding 1 van 2 2008 Honda Pilot Tail Light Assembly Replacement: stap 2, afbeelding 2 van 2
    • Place both hands on the assembly and pull it away from the vehicle.
    • There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
    • If the clips won't disengage try using a rocking motion while pulling on the assembly.
  3. 2008 Honda Pilot Tail Light Assembly Replacement: stap 3, afbeelding 1 van 3 2008 Honda Pilot Tail Light Assembly Replacement: stap 3, afbeelding 2 van 3 2008 Honda Pilot Tail Light Assembly Replacement: stap 3, afbeelding 3 van 3
    • Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
    • Pull the light sockets out of the assembly.
  4. 2008 Honda Pilot Tail Light Assembly Replacement: stap 4, afbeelding 1 van 3 2008 Honda Pilot Tail Light Assembly Replacement: stap 4, afbeelding 2 van 3 2008 Honda Pilot Tail Light Assembly Replacement: stap 4, afbeelding 3 van 3
    • Set the old assembly aside.
    • Take the new assembly, and put the light bulb sockets into their corresponding holes.
    • Twist each socket clockwise to lock them into place.
  5. 2008 Honda Pilot Tail Light Assembly Replacement: stap 5, afbeelding 1 van 3 2008 Honda Pilot Tail Light Assembly Replacement: stap 5, afbeelding 2 van 3 2008 Honda Pilot Tail Light Assembly Replacement: stap 5, afbeelding 3 van 3
    • Line the clips on the back of assembly up with their holes, and push the assembly into place.
    • Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
  6. 2008 Honda Pilot Tail Light Assembly Replacement: stap 6, afbeelding 1 van 1
    • Congratulations! You have installed a new tail light assembly on your vehicle!
Conclusie
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
Één andere persoon heeft deze handleiding voltooid.
John Forsyth
163 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 562
