Ga door naar hoofdinhoud
2008-2013 Volkswagen Golf Tail Light Bulb Replacement
Wat je nodig hebt
  1. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate tail light compartment: stap 1, afbeelding 1 van 1
    • On the driver's side of the vehicle's rear cargo area, locate the rectangular tail light compartment cover.
  2. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove cover: stap 2, afbeelding 1 van 1
    • Using your fingers, gently pull the cover away from the compartment.
  3. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb assembly: stap 3, afbeelding 1 van 1
    • With the cover removed, locate the light bulb assembly.
    • Use a flathead screwdriver to release the locking tab.
  4. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the light bulb assembly: stap 4, afbeelding 1 van 1
    • Pull gently to remove the light bulb assembly.
    • The assembly will remain connected to the vehicle via the wiring harness.
  5. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb: stap 5, afbeelding 1 van 1
    • Turn the assembly so that the smaller tail light bulb and larger fog light bulb are visible.
  6. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the tail light bulb: stap 6, afbeelding 1 van 1
    • Using your fingers, gently pull the tail light bulb out of the socket.
    • Insert a new replacement light bulb into the tail light socket.
    • Excess force may cause light bulbs to break.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Jeffrey Jacquin
284 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-12, Donnelly Fall 2014 Lid van USF Tampa, Team 1-12, Donnelly Fall 2014
USFT-DONNELLY-F14S1G12
1 Lid
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 83
Afgelopen 30 dagen: 378
Altijd: 46,323
