Ga door naar hoofdinhoud
2008-2013 Subaru Forester Cabin Air Filter Replacement
Wat je nodig hebt
  1. 2008-2013 Subaru Forester Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 1 van 1
    • Ensure the vehicle is shut off with the key removed from the ignition before you begin.
    • Open the glovebox located on the passenger side.
  2. 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 2, afbeelding 1 van 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 2, afbeelding 2 van 2
    • Unhook the glovebox retention arm from the side of the glovebox by squeezing the clip together with your fingertips, and prying the arm off the lower connection point only.
    • Gently push the arm up and half way in to prevent accidental breakage.
  3. 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 3, afbeelding 1 van 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 3, afbeelding 2 van 2
    • Starting on either the left or right side, insert screwdriver blade tip into the small catch ramp until it releases.
    • Repeat inserting screwdriver blade tip on opposite side of glovebox and catch ramp until both sides are released and glovebox falls freely open.
  4. 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 4, afbeelding 1 van 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 4, afbeelding 2 van 2
    • Remove the glovebox by pulling horizontally away from its (C shaped) hinge points.
  5. 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 5, afbeelding 1 van 3 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 5, afbeelding 2 van 3 2008-2013 Subaru Forester Cabin Air Filter Replacement: stap 5, afbeelding 3 van 3
    • Open door to filter compartment to access filter.
    • Remove filter media.
    • Note orientation of filter for reinsertion.
Conclusie
Finally, to reinstall the clean cabin air filter, simply follow these same instructions, but in reverse order.
Purchasing and replacing your own cabin filter is simple, time-saving, and resourceful. Congratulations on a job well done!
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 67
Altijd: 6,656
