Ga door naar hoofdinhoud
2008-2013 Nissan Rogue Tail Light Replacement
Wat je nodig hebt
  1. 2008-2013  Nissan Rogue Tail Light Replacement, Tail Light: stap 1, afbeelding 1 van 3 2008-2013  Nissan Rogue Tail Light Replacement, Tail Light: stap 1, afbeelding 2 van 3 2008-2013  Nissan Rogue Tail Light Replacement, Tail Light: stap 1, afbeelding 3 van 3
    • Open the hatch and using a 10MM Socket with a ratchet loosen the bolt holding the tail light assembly in place.
    • Remove the bolt and set it aside.
  2. 2008-2013  Nissan Rogue Tail Light Replacement: stap 2, afbeelding 1 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 2, afbeelding 2 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 2, afbeelding 3 van 3
    • Place a flathead screwdriver in the seam between the tail light assembly and the car and slowly loosen each clip.
    • Standing directly behind the vehicle, use both hands to pull the tail light assembly straight away from the vehicle. If the cover is not pulled straight out you will break the clips that hold the light cover in place.
  3. 2008-2013  Nissan Rogue Tail Light Replacement: stap 3, afbeelding 1 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 3, afbeelding 2 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 3, afbeelding 3 van 3
    • Holding the base of the lightbulb socket, rotate it counter-clockwise to remove it from the light cover.
    • Once the lightbulb socket is removed from the light cover, use two hands to hold the socket and lightbulb and gently pull the lightbulb out of the socket.
  4. 2008-2013  Nissan Rogue Tail Light Replacement: stap 4, afbeelding 1 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 4, afbeelding 2 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 4, afbeelding 3 van 3
    • Place the new lightbulb into the socket, making sure to line the lightbulb up with the socket correctly.
    • Once the new lightbulb is installed, return the lightbulb and socket combo to the light cover. Rotate the socket clockwise to click the socket back into place with the tabs.
  5. 2008-2013  Nissan Rogue Tail Light Replacement: stap 5, afbeelding 1 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 5, afbeelding 2 van 3 2008-2013  Nissan Rogue Tail Light Replacement: stap 5, afbeelding 3 van 3
    • Reinsert the light cover by lining up the two prongs and pushing the light cover straight into the vehicle.
    • The light cover will click into place once re-placed correctly.
    • If the light cover is placed without lining up the prongs you may break the cover attachments.
  6. 2008-2013  Nissan Rogue Tail Light Replacement: stap 6, afbeelding 1 van 2 2008-2013  Nissan Rogue Tail Light Replacement: stap 6, afbeelding 2 van 2
    • Using a 10MM Socket with ratchet tighten the bolt that holds the light cover in place. Once the bolt is tightened, you can close the hatch.
    • Test the new light bulb by testing brakes and using turn signals.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 169
Altijd: 5,769
