Ga door naar hoofdinhoud
2007-2011 Toyota Camry Sun Visor Replacement
Wat je nodig hebt
  1. 2007-2011 Toyota Camry Sun Visor Replacement, Sun Visor: stap 1, afbeelding 1 van 3 2007-2011 Toyota Camry Sun Visor Replacement, Sun Visor: stap 1, afbeelding 2 van 3 2007-2011 Toyota Camry Sun Visor Replacement, Sun Visor: stap 1, afbeelding 3 van 3
    • Remove cap and squeeze metal brackets revealed underneath to loosen and remove from interior of car.
    • Make a note of where the clips of the lever arm fit into the interior of car for reinstatement of the visor later.
  2. 2007-2011 Toyota Camry Sun Visor Replacement: stap 2, afbeelding 1 van 2 2007-2011 Toyota Camry Sun Visor Replacement: stap 2, afbeelding 2 van 2
    • Tear open the seam surrounding the hole that the swing arm inserts into with a seam ripper.
    • Pull the fabric back to show the inner casing.
  3. 2007-2011 Toyota Camry Sun Visor Replacement: stap 3, afbeelding 1 van 2 2007-2011 Toyota Camry Sun Visor Replacement: stap 3, afbeelding 2 van 2
    • Reinsert the swing arm back into the visor, make sure the metal prongs on the swing arm line up with the holes on the visor.
    • The red squares show where the metal prongs fit into the holes of the visor.
  4. 2007-2011 Toyota Camry Sun Visor Replacement: stap 4, afbeelding 1 van 3 2007-2011 Toyota Camry Sun Visor Replacement: stap 4, afbeelding 2 van 3 2007-2011 Toyota Camry Sun Visor Replacement: stap 4, afbeelding 3 van 3
    • Fold the aluminum plate around the outer casing to reinforce the arm in the casing.
    • The metal plate will hold both halves of the visor to the lever arm, so make sure it is secured tightly around visor to keep it together.
    Where did the Aluminum plate come from especially as this was not listed among the things required?
    Sam Azi - Antwoord
    It is listed in the materials list as a “3 1/8 x 7 tie plate,” but the wrong size is given. It should actually be a 1.8” x 5” tie plate, as depicted in the photos, above. You can find this plate at any Home Depot, Lowes Home Improvement, or Ace Hardware (https://www.acehardware.com/departments/...).
    Dave Strasinger - Antwoord
  5. 2007-2011 Toyota Camry Sun Visor Replacement: stap 5, afbeelding 1 van 1
    • Screw a one inch screw through the metal plate and plastic casing using a phillips head screwdriver.
    • Make sure screw goes all the way through to the other side to effectively secure plate to visor.
  6. 2007-2011 Toyota Camry Sun Visor Replacement: stap 6, afbeelding 1 van 2 2007-2011 Toyota Camry Sun Visor Replacement: stap 6, afbeelding 2 van 2
    • Adhere the two halves of the torn seam back together over the outer casing and the aluminum plate​ using upholstery glue.
    • Allow the glue to properly dry before replacing visor back into car.
  7. 2007-2011 Toyota Camry Sun Visor Replacement: stap 7, afbeelding 1 van 3 2007-2011 Toyota Camry Sun Visor Replacement: stap 7, afbeelding 2 van 3 2007-2011 Toyota Camry Sun Visor Replacement: stap 7, afbeelding 3 van 3
    • Realign the metal clips of the swing arm to the hole in the car and snap the visor back into place.
    • If you go back to step one, the hinges are marked to show where the insert the swing arm.
    Becareful not to spring the clips up into the roof of the car. It stops your repair in a hurry.
    Eric Banks - Antwoord
    Question: I ordered a new visor from Amazon. Everything came out as shown, but I seem to be missing the plastic clip that’s shown in the middle small photo here, and looks to be attached to the swing arm assembly in earlier photos. It did not come with the new visor, and was not on the old one. Which may be part of my problem. I can get the new visor in, but if you move it, the whole swing arm with visor falls out. Does anyone know what this part is and how do I buy one?
    Julie Holt - Antwoord
Conclusie
15 andere personen hebben deze handleiding voltooid.
Kimberly Reilly
327 Reputatie
1 Handleiding geschreven
Texas Tech, Team 26-5, Rauch Spring 2016 Lid van Texas Tech, Team 26-5, Rauch Spring 2016
TTU-RAUCH-S16S26G5
3 Leden
3 handleidingen geschreven
25 opmerkingen
How do you remove the visor from the swing arm to begin?
Is there any electrical work you need deal with? it looks like in the first pick there are some wires hanging from the swing arm that I am guessing power the light
Nick - Antwoord
For future readers: simply remove the visor from the ceiling as described in step one. No need to separate the visor from the swing arm in advance. Proceed through the steps as described. I used a 3x5 tie plate (http://www.homedepot.com/p/Simpson-Stron...) and it worked beautifully. I screwed the plate (2nd row of holes) to the edge of a piece of wood about the same thickness as the visor and bend it around that wood as a guide. It resulted in the 1st and 3rd rows of holes aligning so that I could put the screws all the way through and secure with lock nuts. I used #6-32, 1.5" screws (2) and #6-32 locknuts (2). The holes in the tie plate were ever so slightly too small for those screws but a drill bit one size too large for the hole widened it perfectly with ease. The screws were too long (1" was too short) and needed to be cut off with a dremel afterwards. (I couldn't find a 1.25" length screw for the job.)
Dylan Valliere - Antwoord
Well, for most of us the visor has completely fallen off of the swing arm already, so it's a non-issue. But thanks for the condescending reply to the OP who took the time to write an incredibly helpful review.
Betsy Rogers -
This is a Toyota design flaw. It is a safety issue and is negligence on their part not to admit failure and issue recalls. This is in no way isolated to the Camry. It occurs in RAV4s, Tacomas, Highlander's, Tundras and possibly more.
serbirish - Antwoord
My wife's 2012 Venza has this problem, as does my 2011 Camry.
Nevins Parkinson -
Is it necessary to do this repair on a new or used visor? Just bought a 2007 Camry LE, without drivers side visor.
Kenneth Lemons - Antwoord
If I'm understanding the online forums right, Toyota never upgraded the visors so a new visor (really new or used/new to you) are both going to potentially have this problem develop. Since the car install is an absolute breeze, I'd say install a visor and don't do this unnecessary fix until/unless it becomes necessary.
This happened to my 2007 Camry years ago. Sad that Toyota never recalled it as it is huge danger to driving - not only when the visor continuously drops down but also not being able to use it for it's sole purpose - to protect the sun from your eyes while driving.
Thank you for your DIY.
Gwen Carson - Antwoord
Lost one of the metal clips fell inside the cavity of the car is there some where to purchase these clips
mdmonday - Antwoord
There is a factory recall on this for 2007 thru 2011. Check with the dealer or https://www.toyota.com/recall. The above repair is kind of a rig job.
Michael Gans - Antwoord
no recall on 09 Camry
bitsy -
My 2007 Toyota Camry picks up slowly especially from a dead spot or when I slow down. Also vibrates when on speed. How can i fix this.
Luper Shishi - Antwoord
My Toyota Camry 2007 picks up slowly especially from a dead spot or when I slow down. Also vibrates when on speed. How do I fix this?
Hi Luper,
My 2009 LE had this Problem for a long time coupled with the oil vanishing so fast (4 liters every 2 weeks). How did I sort out the issues?
1. If you vehicle has done more than 100k miles, you will need to check your gear oil and probably change it. Please buy Toyota Gear oil (comes in a metal gallon).
2. Check your fuel pump, get it tested to determine if it’s failing or not, you can use the opportunity to wash the fuel filter and the fuel tank too.
3. Check you throttle pedal. The pedal is electronic and can develop faults after so much use. You might need to change it. You might be lucky to get one from a dealer who would let you test it on you car to confirm if the fault is fixed.
4. Clean all the injector nozzles.
5. Check your catalytic converter bank 1 and 2.
Sam Azi -
The left side clip of my sun visor fell off ( drivers side) how can I fix it back it's not a clip on and my mechanic said it can't be fixed. I have a 2003 Toyota Camry sportiva. Pls help!!!
Kurian - Antwoord
My 2008 Camry did the same. I took it in for that accelerator recall/fix and they did something under the floor mats, the accelerator pedal and flashed the computer. The latter was the one that fixed the problem.
louie824 - Antwoord
My problem isn’t with the plastic body inside the visor, but with the tabs in the roof. The rear clip popped out, and the tabs in the roof/ceiling were bent, and I have no idea what they’re supposed to look like.
TJ Fitzgerald - Antwoord
Thanks alot for the genius fix!!!
Ari - Antwoord
I’m looking for a fast, easy fix. Can a large binder clip apply enough pressure to hold the visor in position? I’m going to try that.
kathykgenet - Antwoord
My drivers side visor is flopping down. Evidently it’s a manufacturing defect. Time for Toyota to man up and fix it. I bought my car new .. I’ve never had this type problem with my visor in any car I owned.
monkey21171 - Antwoord
I put a magnet on the visor (next to the mirror) and a matching magnet on the ceiling liner. Both magnets were 1inch square with adhesive backing. Make sure you line them up with the right polarity. I got the magnets at Walmart in the crafts sections. —- Seems to be working OK, but the magnets could be a little stronger. ——- Shame on Toyota for not fixing this design years ago.
Rob K - Antwoord
So, again:
The swing arm is removed in picture (step 2] as you are ripping open seam- how did you get the swing arm to come out? No information provided as to how, just removed between steps 1 & 2. *How* is what we are asking. No need to refer us back to the incomplete instructional as aforementioned.
And if there IS wiring present for lighted mirror (as in my 07 le), then maybe in some models it does not/should not come out… ?
Any positive, non-repetitive feedback is appreciated!
Ang Stroh - Antwoord
I bought a repair kit about 5 yrs ago from CamryVisorRepair.com and it still works great 5 years later. Everything came with it including a prebent bracket much stronger than the one pictured above. It also came with a perfectly match thread and needle and i cant even tell that its been repaired. Also had great step by step videos that showed how to fix all of it.
GEO DEN - Antwoord
The entire replacement visor is approx. $35 right now. How much is your time worth?
William Bethea - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 79
Afgelopen 30 dagen: 463
Altijd: 118,963
