Ga door naar hoofdinhoud
2007-2012 Jeep Wrangler Oil Change
Wat je nodig hebt
  1. 2007-2012 Jeep Wrangler Oil Change, How to open the 2007-2012 Jeep Wrangler hood: stap 1, afbeelding 1 van 2 2007-2012 Jeep Wrangler Oil Change, How to open the 2007-2012 Jeep Wrangler hood: stap 1, afbeelding 2 van 2
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Oil Change: stap 2, afbeelding 1 van 2 2007-2012 Jeep Wrangler Oil Change: stap 2, afbeelding 2 van 2
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Oil Change, 2007-2012 Jeep Wrangler Oil Change: stap 3, afbeelding 1 van 2 2007-2012 Jeep Wrangler Oil Change, 2007-2012 Jeep Wrangler Oil Change: stap 3, afbeelding 2 van 2
    • Before touching any parts, make sure your Jeep Wrangler is off for at least thirty minutes to prevent any burns.
    • Locate the oil cap on the top side of the engine (indicated in red in the image). To remove the cap, twist hard in a counter-clockwise motion.
    • Store the cap in a safe place to prevent losing it.
  4. 2007-2012 Jeep Wrangler Oil Change: stap 4, afbeelding 1 van 1
    • Place the oil drain pan underneath the vehicle.
    • Locate the oil drain plug. It is located at the bottom of the vehicle (indicated by the red square in the image).
    • The pan will need to be directly underneath the oil drain plug in order to catch all of the old oil.
  5. 2007-2012 Jeep Wrangler Oil Change: stap 5, afbeelding 1 van 2 2007-2012 Jeep Wrangler Oil Change: stap 5, afbeelding 2 van 2
    • Using an appropriately sized socket and socket wrench, remove the oil drain plug. (In a pinch, you can use an adjustable wrench.) Twist counter-clockwise to loosen it.
    • Let the oil completely drain from the car and into the drain pan.
    • Replace (reinsert) the plug by twisting it clockwise. Tighten it with the wrench following the same clockwise motion.
    • After the plug is replaced, wipe it down with a dirty rag to clean off any outside oil. This ensures that oil will not drip onto the ground.
    Don't forget the O ring!
    Alex Fairchild - Antwoord
    Recommended torque from Jeep is 20 ft lb
  6. 2007-2012 Jeep Wrangler Oil Change: stap 6, afbeelding 1 van 1
    • Move the drain pan toward the front of the vehicle. Be careful not to spill any oil!
    • Place it directly underneath the oil filter (indicated by the red square in the image). This image is looking down from the front of the engine, underneath the hood.
  7. 2007-2012 Jeep Wrangler Oil Change: stap 7, afbeelding 1 van 3 2007-2012 Jeep Wrangler Oil Change: stap 7, afbeelding 2 van 3 2007-2012 Jeep Wrangler Oil Change: stap 7, afbeelding 3 van 3
    • Oil will begin flowing as soon as you unscrew the filter. Be sure to catch all of the oil in the drain pan.
    • Loosen the oil filter by twisting counter-clockwise. It may be easier to access the oil filter from the top-side of the engine.
    • If it is too difficult to twist by hand, use an oil filter wrench to loosen it.
    • Place the removed oil filter in the oil pan.
  8. 2007-2012 Jeep Wrangler Oil Change: stap 8, afbeelding 1 van 2 2007-2012 Jeep Wrangler Oil Change: stap 8, afbeelding 2 van 2
    • Check the socket for loose bits of the old rubber gasket. Remove these and wipe the area clean.
    • Take the new oil filter and insert it into the socket. Twist it clockwise to fasten it into place.
    • Use the oil filter wrench to ensure that it is a tight fit.
  9. 2007-2012 Jeep Wrangler Oil Change: stap 9, afbeelding 1 van 1
    • On the top of the engine, find the hole for the oil cap you removed earlier.
    • Using a funnel, pour 5.5 quarts of 5W-20 Motor Oil into the hole.
    • Be sure to let all of the oil drain from each oil container.
  10. 2007-2012 Jeep Wrangler Oil Change: stap 10, afbeelding 1 van 1
    • Put the oil cap back on by twisting it clockwise. Check that it is tightly screwed on.
    • Start your engine and let in run for about a minute.
    • Letting your engine run will get the oil flowing inside the engine.
  11. 2007-2012 Jeep Wrangler Oil Change: stap 11, afbeelding 1 van 3 2007-2012 Jeep Wrangler Oil Change: stap 11, afbeelding 2 van 3 2007-2012 Jeep Wrangler Oil Change: stap 11, afbeelding 3 van 3
    • Check the oil level. First, locate the oil dip-stick (marked in the first image by red).
    • Pull out the oil dip-stick and wipe clean it clean with a paper towel or rag.
    • Re-insert the oil dip-stick completely and pull it slowly out.
    • The oil should reach to the safe-fill area on the stick (marked in the image in yellow). If it doesn't, add more fresh oil through the funnel until it reaches this mark.
    • Do not dump your oil down any drain. This is extremely bad for the environment! Act responsibly.
    • Make sure to dispose of your old oil filter and dirty, old oil correctly.
    • Many vehicle repair shops will recycle it free of charge.
Conclusie
Your oil is new, and your oil filter is clean.
11 andere personen hebben deze handleiding voltooid.
Erik Wolken
243 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-51, Forte Fall 2012 Lid van Cal Poly, Team 7-51, Forte Fall 2012
CPSU-FORTE-F12S7G51
5 Leden
9 handleidingen geschreven
Één opmerking
The use of an adjustable wrench to remove the drain-plug is ill-advised. A rounded off plug will be extremely difficult to shift. Get a socket, or a drain plug wrench.
Someone forgot to install the filter gasket ring. They frequently can be found loose in the box, and can be forgotten if you dont know there should be one. But you wont do it a second time!
Jan Xhosa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 180
Altijd: 123,018
