Ga door naar hoofdinhoud
2007-2012 Jeep Wrangler Headlight Replacement
Wat je nodig hebt
  1. 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: stap 1, afbeelding 1 van 2 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: stap 1, afbeelding 2 van 2
    • Locate the two gray latches on either side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Headlight Replacement: stap 2, afbeelding 1 van 2 2007-2012 Jeep Wrangler Headlight Replacement: stap 2, afbeelding 2 van 2
    • Reach under the hood and push the lever left to right. You should now be able to lift the hood.
    • Prop open the hood by inserting the support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Headlight Replacement: stap 3, afbeelding 1 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 3, afbeelding 2 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 3, afbeelding 3 van 3
    • Locate all six push on fasteners on the top of the grill.
    • Use a flathead screwdriver to pry up the fasteners, and make sure you put the screws somewhere safe.
    • If the fasteners will not come up, use two flathead screwdrivers on either side of the fastener to remove.
  4. 2007-2012 Jeep Wrangler Headlight Replacement: stap 4, afbeelding 1 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 4, afbeelding 2 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 4, afbeelding 3 van 3
    • Locate right and left blinker lights under the fenders.
    • Twist blinker light toward the ground, and make sure you pull the bulb out carefully.
    • Make sure you are handling bulb carefully.
  5. 2007-2012 Jeep Wrangler Headlight Replacement: stap 5, afbeelding 1 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 5, afbeelding 2 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 5, afbeelding 3 van 3
    • Make sure all fasteners are removed from top of the grill, and the top of the grill is loose.
    • Firmly pull the bottom of the grill until the grill disconnects from the jeep.
  6. 2007-2012 Jeep Wrangler Headlight Replacement: stap 6, afbeelding 1 van 2 2007-2012 Jeep Wrangler Headlight Replacement: stap 6, afbeelding 2 van 2
    • Locate the 4 screws holding the headlight in place.
    • Use a star bit screwdriver to unscrew the .164-18 x .625 mm star bit screws around the headlight, and make sure you place screws somewhere safe.
    • Hold the headlight when unscrewing last screw to prevent the headlight from falling.
  7. 2007-2012 Jeep Wrangler Headlight Replacement: stap 7, afbeelding 1 van 2 2007-2012 Jeep Wrangler Headlight Replacement: stap 7, afbeelding 2 van 2
    • Use your hands to carefully remove silver ring from the headlight.
  8. 2007-2012 Jeep Wrangler Headlight Replacement: stap 8, afbeelding 1 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 8, afbeelding 2 van 3 2007-2012 Jeep Wrangler Headlight Replacement: stap 8, afbeelding 3 van 3
    • Locate red tab on the headlight plug connector, and push it away from the headlight.
    • Firmly pull the connector away from headlight to remove.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Marco Santini
290 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-3, Green Fall 2015 Lid van Cal Poly, Team 17-3, Green Fall 2015
CPSU-GREEN-F15S17G3
4 Leden
3 handleidingen geschreven
3 opmerkingen
Could Jeep make it more difficult to do simple maintenance? I doubt it!
Linda Procida - Antwoord
What is that green connector called? I’m having trouble putting new lights because none of the converters fit.
Alex - Antwoord
What it is the recommended torque to screw it back?
Luis Vitorio Cargnini - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 76
Altijd: 20,385
