Ga door naar hoofdinhoud
2006 Honda Shadow Spirit 750 Battery Replacement
Wat je nodig hebt
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: stap 1, afbeelding 1 van 1
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: stap 2, afbeelding 1 van 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: stap 2, afbeelding 2 van 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: stap 2, afbeelding 3 van 3
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: stap 3, afbeelding 1 van 2 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: stap 3, afbeelding 2 van 2
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: stap 4, afbeelding 1 van 1
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: stap 5, afbeelding 1 van 1
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: stap 6, afbeelding 1 van 1
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: stap 7, afbeelding 1 van 1
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: stap 8, afbeelding 1 van 1
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: stap 9, afbeelding 1 van 1
    • Remove the battery from the bike by pulling upwards.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Dazarene Cascio
736 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-7, Donnelly Fall 2014 Lid van USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 Lid
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 82
Altijd: 19,057
