Inleiding
This guide will show how to replace the wiper motor. Some standard tools will be needed such as screwdrivers, sockets, wrenches, etc. This replacement is relatively simple and should not take more than one hour for completion.
Wat je nodig hebt
Use a plastic prying tool or spudger to gently remove nut cap from wiper base.
Use a 5/8 wrench or socket to remove the necessary nut holding the wiper in place.
Once the necessary nuts are removed, the wiper blade itself can be removed.
This can be done easiest by first flexing the wiper to the upright position, then gently pulling the wiper off of the screw.
Open the hood of the truck for easier access to the wiper cowl.
Using pliers, locate the six retainer clips on the plastic cowl and remove them by pulling straight up.
Position your hands underneath the wiper cowl and start to gently loosen the plastic from the windshield.
Pull straight towards the front of the truck to slide the wiper cowl over the screws that held the wiper blades, exposing the wiper components underneath.
Rotate assembly towards the windshield while starting to remove it from the truck.
Unplug the wiring harness located towards the driver's side of the truck.
The wire can then be fed through to remove the assembly the rest of the way.
Remove the connecting arm socket with a 1/2 inch wrench or socket (red circle).
Remove the three motor bolts with a 10mm wrench or socket (orange circles).
The wiper motor is now able to be replaced.
3 andere personen hebben deze handleiding voltooid.
