Ga door naar hoofdinhoud
2006-2011 Honda Civic Key FOB Battery Replacement
Wat je nodig hebt
  1. 2006-2011 Honda Civic Key FOB Battery Replacement, Key FOB Battery: stap 1, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
  2. 2006-2011 Honda Civic Key FOB Battery Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the outer shell and remove it from the rest of the device.
    • Be careful not to break the clip located at the hole for the key ring that holds the shell in place.
  3. 2006-2011 Honda Civic Key FOB Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
  4. 2006-2011 Honda Civic Key FOB Battery Replacement: stap 4, afbeelding 1 van 1
    • Unclasp the inner shell using the clips on the top and bottom.
    • Careful as to not break the clips as it keeps moisture, dust, and dirt from entering the delicate electronics.
  5. 2006-2011 Honda Civic Key FOB Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery inside of the inner shell of the key FOB.
    • If the battery is corroded, make sure to wear gloves due to battery acid.
    • Do not puncture the battery when removing the old one/placing a new one.
  6. 2006-2011 Honda Civic Key FOB Battery Replacement: stap 6, afbeelding 1 van 1
    • Replace the old battery with a new one.
Conclusie
To reassemble your key FOB, follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Erika Caushi
223 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 79
Afgelopen 7 dagen: 499
Afgelopen 30 dagen: 2,254
Altijd: 65,614
