Inleiding
If your dome light bulb is burnt out or you want better quality lighting inside your vehicle, this guide will help you replace your dome lights in a 2006-2011 Honda Civic.
Dome lights are helpful when entering and exiting your vehicle. Without it, it may be challenging to see at night.
Before using this guide, make sure the old bulb is not loose. On some rare occasions, the bulb can come loose, causing the light not to work.
While following this guide, you must be gentle with the replacement bulb to avoid any damage. Also, handle the plastic dome light cover with care.
There are no special skills required to complete this replacement guide.
Wat je nodig hebt
Turn on the dome light by pressing the light.
Press in once again, but do not release.
Insert a screwdriver or plier into the lifted side of the cover and gently push down.
To reassemble your device, please follow step 4.
Één andere persoon heeft deze handleiding voltooid.
