Ga door naar hoofdinhoud
2006-2013 Toyota Corolla Ignition Coil Replacement
Wat je nodig hebt
  1. 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: stap 1, afbeelding 1 van 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: stap 1, afbeelding 2 van 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: stap 1, afbeelding 3 van 3
    • Pop the hood and remove the black plastic cover over the engine.
    • There is nothing to unscrew, or unlatch, and the cover should lift off. Once removed, the top of the engine will look like the third picture
  2. 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 2, afbeelding 1 van 2 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 2, afbeelding 2 van 2
    • Unplug the ignition coil you wish to replace. The coils are numbered one though four, left to right.
    • Do not unscrew the bolt on the ignition coil before this step. It makes the electrical plug more difficult to remove
  3. 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the bolt of the coil that needs to be replaced.
    • Be sure to put the bolt in a place you will not lose it!
  4. 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 4, afbeelding 1 van 2 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 4, afbeelding 2 van 2
    • Pull the coil straight up and out. It should come off of the spark plug with little resistance.
  5. 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 5, afbeelding 1 van 2 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 5, afbeelding 2 van 2
    • Apply a pea-sized amount of grease to the new ignition coil. It should be all around the rubber tip around the bottom.
    • While not required, this step will make any future replacements much easier.
  6. 2006-2013 Toyota Corolla Ignition Coil Replacement: stap 6, afbeelding 1 van 1
    • When inserting the new ignition coil, press down lightly to ensure it is completely in place.
    • Re-plugging in the ignition coil, and re-screw it in. This can be preformed in either order.
    • Repeat steps three through five as necessary for the other three ignition coils.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Henderson Gillette
160 Reputatie
1 Handleiding geschreven
Één opmerking
Excelente explicación, muy clara y detallada
Oscar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 368
Altijd: 1,815
