Inleiding
This guide will show you how to replace the faulty liftgate latch/back lock sub-assembly and how to open a stuck trunk door for a 2005 Toyota Sequoia.
The Toyota Sequoia has a well-known fault that results in the trunk door remaining locked or unable to close properly. This can either make accessing the trunk more difficult or may potentially cause a hazardous situation where the trunk opens while driving. This is because the liftgate latch may have gotten jammed or cracked the fragile actuator motor it is attached to.
Wat je nodig hebt
