Ga door naar hoofdinhoud
2005 Honda Accord Opening Hood Guide
  1. 2005 Honda Accord Opening Hood Guide, 2005 Honda Accord Opening Hood Guide: stap 1, afbeelding 1 van 2 2005 Honda Accord Opening Hood Guide, 2005 Honda Accord Opening Hood Guide: stap 1, afbeelding 2 van 2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  2. 2005 Honda Accord Opening Hood Guide: stap 2, afbeelding 1 van 3 2005 Honda Accord Opening Hood Guide: stap 2, afbeelding 2 van 3 2005 Honda Accord Opening Hood Guide: stap 2, afbeelding 3 van 3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
Conclusie
To close hood, lower to 6 inches above engine, then drop hood. If you do not hear the latch reengage, push down on hood or try dropping hood from a higher level.
4 andere personen hebben deze handleiding voltooid.
Matt Ondriezek
486 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-35, Maness Spring 2014 Lid van Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Leden
5 handleidingen geschreven
2 opmerkingen
Don’t you think that people usually access this guide when the hood is stuck closed? In which case these instructions are no more helpful than those in the owner’s manual. I’ve opened the hood of my 2005 Honda Civic countless times, until this morning. Interior release functions just fine, but the secondary release does nothing.
David - Antwoord
Cable from inside hood release is broken need diagrams to show mechanism under driver's side fender to show how to replace it.
William McNeil - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 50
Altijd: 37,872
