Ga door naar hoofdinhoud
2005 Honda Accord Engine Oil Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. 2005 Honda Accord Engine Oil Replacement, Using a Jack: stap 1, afbeelding 1 van 2 2005 Honda Accord Engine Oil Replacement, Using a Jack: stap 1, afbeelding 2 van 2
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
  2. 2005 Honda Accord Engine Oil Replacement: stap 2, afbeelding 1 van 2 2005 Honda Accord Engine Oil Replacement: stap 2, afbeelding 2 van 2
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
  3. 2005 Honda Accord Engine Oil Replacement, 2005 Honda Accord Opening Hood Guide: stap 3, afbeelding 1 van 2 2005 Honda Accord Engine Oil Replacement, 2005 Honda Accord Opening Hood Guide: stap 3, afbeelding 2 van 2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  4. 2005 Honda Accord Engine Oil Replacement: stap 4, afbeelding 1 van 3 2005 Honda Accord Engine Oil Replacement: stap 4, afbeelding 2 van 3 2005 Honda Accord Engine Oil Replacement: stap 4, afbeelding 3 van 3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  5. 2005 Honda Accord Engine Oil Replacement, Engine Oil: stap 5, afbeelding 1 van 2 2005 Honda Accord Engine Oil Replacement, Engine Oil: stap 5, afbeelding 2 van 2
    • Pull out the dipstick
    • Unscrew the cap from the oil tank
    • Set both aside. lay a towel over the engine block and set dipstick and the cap on that to avoid traces of oil.
  6. 2005 Honda Accord Engine Oil Replacement: stap 6, afbeelding 1 van 3 2005 Honda Accord Engine Oil Replacement: stap 6, afbeelding 2 van 3 2005 Honda Accord Engine Oil Replacement: stap 6, afbeelding 3 van 3
    • Place oil pan between the front tires
    • Lay down and slide yourself headfirst under the front of the car. To the side of the right tire you will see the oil tank.
    • Loosen the drain bolt with a 17mm wrench. Once loose, use your hand to unscrew the rest of the way.
    • Once the bolt is removed, oil will pour out of the hole very quickly. Position the oil pan under the hole before completely removing the screw.
    • Allow oil to drain until the flow is reduced to a slow drip.
  7. 2005 Honda Accord Engine Oil Replacement: stap 7, afbeelding 1 van 2 2005 Honda Accord Engine Oil Replacement: stap 7, afbeelding 2 van 2
    • Replace the crush washer on the drain bolt with a new one.
    • Put the drain bolt back into the oil tank and tighten with 29 ft-lb of torque.
  8. 2005 Honda Accord Engine Oil Replacement: stap 8, afbeelding 1 van 1
    • Using a funnel, pour the new oil into the oil tank.
    • Honda recommends using 4 quarts of their synthetic blend 5w-20 Motor oil.
  9. 2005 Honda Accord Engine Oil Replacement: stap 9, afbeelding 1 van 3 2005 Honda Accord Engine Oil Replacement: stap 9, afbeelding 2 van 3 2005 Honda Accord Engine Oil Replacement: stap 9, afbeelding 3 van 3
    • Put the dipstick back in.
    • Put the oil tank cap back on.
    • close the hood.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Frank
291 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-35, Maness Spring 2014 Lid van Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Leden
5 handleidingen geschreven
2 opmerkingen
Thanks. I was never able to find the oil filter before. Note that the Honda owner's manual lists oil capacity at 4.5 quarts, whereas you say 4 quarts; I don't know if this makes a difference.
JMY - Antwoord
Well-done.
The only issue I have is that I don't have the tools.
The explanations are ok
Olayinka Erinfolami - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 142
Altijd: 49,640
