Ga door naar hoofdinhoud
2005 Honda Accord Cabin Air Filter Replacement
Wat je nodig hebt
  1. 2005 Honda Accord Cabin Air Filter Replacement, Open the glove box: stap 1, afbeelding 1 van 2 2005 Honda Accord Cabin Air Filter Replacement, Open the glove box: stap 1, afbeelding 2 van 2
    • Locate the glove compartment on the passenger side of the vehicle.
    • Unlatch the glove compartment and allow it to fully open.
  2. 2005 Honda Accord Cabin Air Filter Replacement, Unhook the glove box damper arm latch: stap 2, afbeelding 1 van 2 2005 Honda Accord Cabin Air Filter Replacement, Unhook the glove box damper arm latch: stap 2, afbeelding 2 van 2
    • Locate the glove box damper assy latch on the right side of the glove compartment.
    • Unhook the latch from the glove compartment by pushing it towards the front of the car.
  3. 2005 Honda Accord Cabin Air Filter Replacement, Release the glove box stops: stap 3, afbeelding 1 van 2 2005 Honda Accord Cabin Air Filter Replacement, Release the glove box stops: stap 3, afbeelding 2 van 2
    • Firmly grab both sides of the glove compartment.
    • Push the sides of the glove compartment inward and drop the entire glove box down to release it from the dashboard. Support the glove box with your leg.
  4. 2005 Honda Accord Cabin Air Filter Replacement, Remove the cabin air filter tray: stap 4, afbeelding 1 van 3 2005 Honda Accord Cabin Air Filter Replacement, Remove the cabin air filter tray: stap 4, afbeelding 2 van 3 2005 Honda Accord Cabin Air Filter Replacement, Remove the cabin air filter tray: stap 4, afbeelding 3 van 3
    • Locate the cover for the cabin air filter and notice the two tabs on either side.
    • Press on both tabs of the cover and pull the cover outwards towards you to reveal the cabin air filter.
    • Pull the cover all the way out.
  5. 2005 Honda Accord Cabin Air Filter Replacement, Remove and replace the cabin air filter: stap 5, afbeelding 1 van 2 2005 Honda Accord Cabin Air Filter Replacement, Remove and replace the cabin air filter: stap 5, afbeelding 2 van 2
    • Pull the air filter out of the cover.
    • When putting in the new filter, be sure to line up the air flow arrows on the filter with the arrows on the front of the cover.
Conclusie
Reinstall the cabin air filter tray, and reinstall the glove box in reverse order as the earlier steps.
7 andere personen hebben deze handleiding voltooid.
Frank
291 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-35, Maness Spring 2014 Lid van Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 58
Altijd: 12,886
