Ga door naar hoofdinhoud
2005 Ford Focus ZXW Tail Light Bulb Replacement
Wat je nodig hebt
  1. 2005 Ford Focus ZXW Tail Light Bulb Replacement, Tail Light Bulb: stap 1, afbeelding 1 van 2 2005 Ford Focus ZXW Tail Light Bulb Replacement, Tail Light Bulb: stap 1, afbeelding 2 van 2
    • Open the trunk door.
  2. 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 2, afbeelding 1 van 2 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 2, afbeelding 2 van 2
    • Remove the two screws with the Phillips screwdriver, rotating counter clockwise.
    • The taillight housing can now be detached from the vehicle.
  3. 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 3, afbeelding 1 van 3 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 3, afbeelding 2 van 3 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 3, afbeelding 3 van 3
    • Gently pull the detached taillight housing away from the vehicle.
    • There will be wires attached to two different bulb sockets.
  4. 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 4, afbeelding 1 van 2 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the harness from the bulb socket by pushing in on the tabs and pulling.
    • Removing the harness from the bulb socket might require some force. Try moving the harness back and forth while pushing on the tabs if you are having trouble removing the harness.
    • Repeat the last two steps to disconnect the second harness from the bulb socket.
  5. 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 5, afbeelding 1 van 2 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 5, afbeelding 2 van 2
    • Remove the damaged bulb by firmly gripping the bulb and pulling.
    • Removing the bulb from the socket may require some force.
    • Be careful while handling the bulb as it may break.
  6. 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 6, afbeelding 1 van 2 2005 Ford Focus ZXW Tail Light Bulb Replacement: stap 6, afbeelding 2 van 2
    • Place the new bulb in the bulb socket.
    • Repeat this process to replace the second bulb.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Megn Thomason
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 873
