Ga door naar hoofdinhoud
2005-2012 Toyota RAV4 Headlight Replacement
  1. 2005-2012 Toyota RAV4 Headlight Replacement, Headlight: stap 1, afbeelding 1 van 1
    • Turn off your car, use your emergency break to secure the car and pop open the hood.
    • Make sure the engine is not hot before working under the hood of the car.
  2. 2005-2012 Toyota RAV4 Headlight Replacement: stap 2, afbeelding 1 van 2 2005-2012 Toyota RAV4 Headlight Replacement: stap 2, afbeelding 2 van 2
    • Under the hood of the car, locate a black cable towards the grille on the drivers side that leads to the back of the headlight. The bulb is located here.
  3. 2005-2012 Toyota RAV4 Headlight Replacement: stap 3, afbeelding 1 van 3 2005-2012 Toyota RAV4 Headlight Replacement: stap 3, afbeelding 2 van 3 2005-2012 Toyota RAV4 Headlight Replacement: stap 3, afbeelding 3 van 3
    • Turn the bulb counter-clockwise using your hand and gently pull the headlight out.
  4. 2005-2012 Toyota RAV4 Headlight Replacement: stap 4, afbeelding 1 van 2 2005-2012 Toyota RAV4 Headlight Replacement: stap 4, afbeelding 2 van 2
    • The headlight is attached to a plug that has a clip. Push down on the clip and pull the bulb out at the same time with the opposite hand.
  5. 2005-2012 Toyota RAV4 Headlight Replacement: stap 5, afbeelding 1 van 3 2005-2012 Toyota RAV4 Headlight Replacement: stap 5, afbeelding 2 van 3 2005-2012 Toyota RAV4 Headlight Replacement: stap 5, afbeelding 3 van 3
    • Slide the new bulb into that same plug until you hear a click.
  6. 2005-2012 Toyota RAV4 Headlight Replacement: stap 6, afbeelding 1 van 2 2005-2012 Toyota RAV4 Headlight Replacement: stap 6, afbeelding 2 van 2
    • Put the bulb into the same hole that it was removed from and turn clockwise until you hear another click. You are done!
Conclusie
3 andere personen hebben deze handleiding voltooid.
Thaiz Cruz
223 Reputatie
1 Handleiding geschreven
Één opmerking
This is a headlight BULB replacement, not a headlight replacement. Please consider changing the title, which is misleading. Thank you.
Barb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 235
Altijd: 9,555
