Ga door naar hoofdinhoud
2004-2007 Chevrolet Malibu Headlight Replacement
Wat je nodig hebt
  1. 2004-2007 Chevrolet Malibu Headlight Replacement, Removing Screws: stap 1, afbeelding 1 van 1
    • First pop the hood of the car and locate the headlight. They are towards the front of the car.
  2. 2004-2007 Chevrolet Malibu Headlight Replacement: stap 2, afbeelding 1 van 3 2004-2007 Chevrolet Malibu Headlight Replacement: stap 2, afbeelding 2 van 3 2004-2007 Chevrolet Malibu Headlight Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the 10 mm screws attaching the headlight to the car.
  3. 2004-2007 Chevrolet Malibu Headlight Replacement, Take out the headlight: stap 3, afbeelding 1 van 2 2004-2007 Chevrolet Malibu Headlight Replacement, Take out the headlight: stap 3, afbeelding 2 van 2
    • Remove the headlight so you can see all wiring going from the car and to the headlight.
  4. 2004-2007 Chevrolet Malibu Headlight Replacement, Safety Caps: stap 4, afbeelding 1 van 2 2004-2007 Chevrolet Malibu Headlight Replacement, Safety Caps: stap 4, afbeelding 2 van 2
    • Remove the safety caps to get a good a view of your bulb wiring.
  5. 2004-2007 Chevrolet Malibu Headlight Replacement, Remove the Bulb: stap 5, afbeelding 1 van 1
    • Turn the bulb counter clockwise then pull it out.
  6. 2004-2007 Chevrolet Malibu Headlight Replacement, Separate the bulb and pigtail: stap 6, afbeelding 1 van 2 2004-2007 Chevrolet Malibu Headlight Replacement, Separate the bulb and pigtail: stap 6, afbeelding 2 van 2
    • Pull back the clip that's holding the bulb (top half) and the pigtail (bottom half) together.
    • Pull apart the two, exposing the inside of the damaged pigtail.
  7. 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: stap 7, afbeelding 1 van 3 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: stap 7, afbeelding 2 van 3 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: stap 7, afbeelding 3 van 3
    • Now that you have separated the bulb and pigtail, detach the pigtail end from the car wires using wire cutters or scissors.
    • How To Cut With Wire Cutters
    • After cutting the wires, grab your new pigtail and pull back the rubber surrounding the wire. Pull back the rubber so there is enough wire to twist (connect) to the car wire.
  8. 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: stap 8, afbeelding 1 van 3 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: stap 8, afbeelding 2 van 3 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: stap 8, afbeelding 3 van 3
    • Once you've connected the pigtail back to the car be sure to wrap the wire in electrical tape.
    • Then grab your new bulb and attach it to the new pigtail by pushing it together until the clip has clicked.
    • Put the safety caps back on.
  9. 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: stap 9, afbeelding 1 van 3 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: stap 9, afbeelding 2 van 3 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: stap 9, afbeelding 3 van 3
    • Take your new bulb and place it back inside the headlight by twisting clockwise and making sure it doesn't come out or disconnect.
    • Reattach the headlight to the car with the 10 mm screws using a Phillips #0 screwdriver.
Conclusie
To replace your headlight, follow these simple instructions.
Nadia Simpson
421 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 36
Altijd: 3,070
