Ga door naar hoofdinhoud
2004-2008 Mazda RX-8 Tire Rotation
Wat je nodig hebt
  1. 2004-2008 Mazda RX-8 Tire Rotation, 2004-2008 Mazda RX-8 Tire Rotation: stap 1, afbeelding 1 van 1
    • Loosen lug nuts with the socket/wrench just until they begin to turn.
    • Removing lug nuts requires a 21mm socket.
  2. 2004-2008 Mazda RX-8 Tire Rotation: stap 2, afbeelding 1 van 3 2004-2008 Mazda RX-8 Tire Rotation: stap 2, afbeelding 2 van 3 2004-2008 Mazda RX-8 Tire Rotation: stap 2, afbeelding 3 van 3
    • Place Jack under the car (as shown).
    • It's best to avoid using the jack included with the car. If at all possible, use at least a 2 ton floor jack.
    • Use the Jack Handle to crank up just enough so that the tire noticeably lifts off the ground.
  3. 2004-2008 Mazda RX-8 Tire Rotation: stap 3, afbeelding 1 van 1
    • Put the jack stand under the car to ensure the car will not fall back down while you are working on it.
  4. 2004-2008 Mazda RX-8 Tire Rotation: stap 4, afbeelding 1 van 1
    • Remove all lug nuts holding the wheel on the car.
  5. 2004-2008 Mazda RX-8 Tire Rotation: stap 5, afbeelding 1 van 1
    • Remove the front wheel from the vehicle.
  6. 2004-2008 Mazda RX-8 Tire Rotation: stap 6, afbeelding 1 van 1
    • With the front wheel off repeat step 4 and step 5 to remove the rear wheel as well.
  7. 2004-2008 Mazda RX-8 Tire Rotation: stap 7, afbeelding 1 van 1
    • Place the rear wheel on the front of the car and place the front wheel in the rear. Tighten up the lug nuts and your tire rotation is complete.
    • Begin to tighten the lug nuts as much as you can with the wheel in the air, and then lower the car to the ground to finish tightening.
    • Tighten the nuts in a star pattern to avoid over tightening one side leaving the wheel installed crooked
    • Mazda recommends that the lug nuts be torqued to 108 ft*lbs to ensure that the wheel is secure
Conclusie
Verify a second time that every piece nut is secure and tight. You may have to do this again in the future.
Gerrit Mouw
253 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-4, Regan Spring 2015 Lid van Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 2,287
