Ga door naar hoofdinhoud
2004-2008 Mazda RX-8 Battery Replacement
Wat je nodig hebt
  1. 2004-2008 Mazda RX-8 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 2004-2008 Mazda RX-8 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 2004-2008 Mazda RX-8 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Find black tabs that lock Battery cover into place.
    • The tabs should snap off easily.
  2. 2004-2008 Mazda RX-8 Battery Replacement: stap 2, afbeelding 1 van 2 2004-2008 Mazda RX-8 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
    • It is vital to disconnect the negative terminal before interacting with the battery. Make sure not to bridge the two terminals with your wrench or other tools.
    • Remove the terminals once nuts are completely loose.
  3. 2004-2008 Mazda RX-8 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove Battery terminals.
  4. 2004-2008 Mazda RX-8 Battery Replacement: stap 4, afbeelding 1 van 1
    • Using the 10mm Wrench remove gold nuts that hold the retention bar in place.
  5. 2004-2008 Mazda RX-8 Battery Replacement: stap 5, afbeelding 1 van 1
    • After removing the bar pull the dead battery out using the black straps.
Conclusie
After replacing the device, follow these instructions in reverse order to secure a new battery in its place.
Gerrit Mouw
253 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-4, Regan Spring 2015 Lid van Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Leden
5 handleidingen geschreven
Één opmerking
Thanks!...Ron
sgt.splem - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 66
Altijd: 15,823
