Ga door naar hoofdinhoud
2004-2008 Ford F150 Tail Light Bulb Replacement
Wat je nodig hebt
  1. 2004-2008 Ford F150 Tail Light Bulb Replacement, Tail Light Bulb: stap 1, afbeelding 1 van 1
    • Park the vehicle on a level surface.
    • Turn the vehicle off.
    • If the vehicle is not turned off, there is a risk of electrocution upon removal of the tail light.
  2. 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 2, afbeelding 1 van 1
    • Lower the tailgate.
  3. 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 3, afbeelding 1 van 3 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 3, afbeelding 2 van 3 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 3, afbeelding 3 van 3
    • Use the 8mm socket wrench to remove both of the mounting bolts.
    • An 8mm crescent wrench can be used in place of the 8mm socket wrench.
  4. 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 4, afbeelding 1 van 2 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 4, afbeelding 2 van 2
    • Remove the tail light by pulling the tail light housing straight back, away from the vehicle.
    • If the tail light housing is too difficult to remove use a thin, stiff piece of plastic as a pry bar to aid in removing the tail light housing.
    • If a pry bar is used, take caution to not scratch the paint of the vehicle.
  5. 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 5, afbeelding 1 van 1
    • Twist the upper socket counter clockwise.
    • Pull back to remove the socket from the tail light assembly.
  6. 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 6, afbeelding 1 van 2 2004-2008 Ford F150 Tail Light Bulb Replacement: stap 6, afbeelding 2 van 2
    • Pull the bulb out of the socket.
    • When handling the replacement bulb, be careful to minimize contact with the bulb itself; as the oils from your hand can decrease the lifespan of the bulb.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Eric Carnes
274 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 65
Altijd: 10,502
