Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Take a look at the belt routing diagram under the hood. If you didn't find it you can find a picture on the internet or draw one before beginning.
look carefully at how the old belt wraps around the pulleys, so you can replace the new one by practicing and matching the routing.
A/C Pulley
Tensioner
Idler Pulley
Crankshaft Pulley
Power Steering Pump Pulley
Generator Pulley
Water Pump Pulley
Now, use your 16 mm wrench to reduce the belt tension and get it off.
Put the socket wrench on the tensioner (Right your belt tensioner, the little square or cave).
Remove the old belt and make sure to put the new belt that doesn't have any cracks and looks smooth.
Install the new belt by lining up all belt ribs in the pulley grooves and wrap it around.
Start with the A/C Pulley and then wrap it around the tensioner and move on until you end up with the water pump pulley.
Make sure at the end to tighten the tensioner and start your car to make sure it's work!
