Ga door naar hoofdinhoud
2003-2006 Chevrolet Silverado Headlight Bulb Replacement
Wat je nodig hebt
  1. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: stap 1, afbeelding 1 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: stap 1, afbeelding 2 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: stap 1, afbeelding 3 van 3
    • Turn your vehicle off, and let the engine bay cool before starting the following steps.
    • First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck.
    • Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
    • Make sure to put the pin in a safe location so you can lock in the housing once you finish replacing the light bulbs.
  2. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: stap 2, afbeelding 1 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: stap 2, afbeelding 2 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: stap 2, afbeelding 3 van 3
    • Pinch the blue clips and remove them from the back of the wiring harness.
    • After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
    • Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
  3. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: stap 3, afbeelding 1 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: stap 3, afbeelding 2 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: stap 3, afbeelding 3 van 3
    • Unbox your new low beam light, and insert it into the same hole you took the old one out of.
    • Be sure to twist the bulb clockwise until it locks into place with the harness pointing down.
    • Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
  4. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: stap 4, afbeelding 1 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: stap 4, afbeelding 2 van 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: stap 4, afbeelding 3 van 3
    • Begin to replace the headlight housing back into its original place by tucking in the wires.
    • Grab the pin that you took out at the beginning and insert it back into the housing unit.
    • Align the housing back with the guide holes for the pin.
  5. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: stap 5, afbeelding 1 van 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: stap 5, afbeelding 2 van 2
    • Follow steps 1-4 for the other headlight to replace the low beam headlight.
    • Make sure to keep track of all of your parts and dispose of your old bulbs properly.
    • Be sure to check your headlight alignment. This can be done by a professional or through Youtube videos.
Conclusie
To replace the other light bulb just follow the same steps as above.
5 andere personen hebben deze handleiding voltooid.
Alisson Silva
197 Reputatie
1 Handleiding geschreven
Één opmerking
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
Jay Wilhoite - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 56
Altijd: 41,479
