Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
It's recommended that you change your spark plugs every 30,000 miles.
  1. Locate the hood latch beside the driver's side door, right next to the left foot rest. Locate the hood latch beside the driver's side door, right next to the left foot rest.
    • Locate the hood latch beside the driver's side door, right next to the left foot rest.
  2. Pull the latch toward you to release the hood.
    • Pull the latch toward you to release the hood.
  3. Walk around to the front of the vehicle. Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  4. Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
  5. Place the tip of the hood stand into the hole located in the upper left of the hood.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • Let the hood rest on the stand.
  6. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  7. Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place. Lift the plastic cover and set it aside.
    • Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place.
    • Lift the plastic cover and set it aside.
  8. Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out. Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out. Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
    • Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
  9. Use a 10 mm hex driver or socket to remove the four spark plug boot screws. Use a 10 mm hex driver or socket to remove the four spark plug boot screws.
    • Use a 10 mm hex driver or socket to remove the four spark plug boot screws.
  10. Lift the boot screws out of the spark plug bores. Lift the boot screws out of the spark plug bores. Lift the boot screws out of the spark plug bores.
    • Lift the boot screws out of the spark plug bores.
  11. Locate the spark plug at the bottom of the bore. Use a ratchet, extension, and 5/8 inch socket to remove the plug by turning counterclockwise until it's free.
    • Locate the spark plug at the bottom of the bore.
    • Use a ratchet, extension, and 5/8 inch socket to remove the plug by turning counterclockwise until it's free.
  12. Pull the plug out of the bore. Pull the plug out of the bore. Pull the plug out of the bore.
    • Pull the plug out of the bore.
  13. Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
    • Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
    • The gap is bridged by corrosion.
    • The gap is too large.
    • The area around the gap is black and dark.
  14. If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
    • If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
    • Use of Anti-Seize on the thread of spark plug is highly recommended to ensure threads don't get damaged while tightening.
    • Use a ratchet, extension, and 5/8 inch socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
    • If a torque wrench is available, tighten to 13 ft-lbs.
    • Repeat Steps 10-13 for the three remaining spark plugs.
Conclusie
After reinstalling all four spark plugs, follow Steps 3-9 in reverse order to reattach the spark plug cover and close the car's hood.
29 andere personen hebben deze handleiding voltooid.
Shaun MacDonald
2.256 Reputatie
8 handleidingen geschreven
Cal Poly, Team 24-27, Regan Fall 2012 Lid van Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Leden
18 handleidingen geschreven
Great instructions! I was able to change them pretty quickly.
JOEL DENNIS - Antwoord
First rule of thumb when changing spark plugs is to do it when the engine is cold. If you don't have a torque wrench it's ok, you can still tighten them properly. Easiest thing to do is put the new plug in the spark plug socket, attach the extension (8 or 10 in. is perfect) but not the ratchet. Thread the plug in until it is snug, then attach the ratchet to tighten. Most spark plug manufacturers put on the box (especially NGK) how much to tighten. Usually if the plug has no gasket, tighten 1/16 to 1/8 of a turn. If it has a gasket, tighten 1/2 to 2/3 of a turn. For an '05 Accord 4 cyl. they have a gasket.
wingmaneh - Antwoord
Thanks for the clear instructions & photos!
Steve T - Antwoord
I appreciate the thorough and precise instructions. I would add using anti-seize on new plug threads.
ssnider727 - Antwoord
On an '05 Accord, are there any wires that need to be replaced at a regular interval?
Ryan Roux - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 85
Afgelopen 30 dagen: 420
Altijd: 80,031
