Ga door naar hoofdinhoud
2003-2007 Honda Accord Interior Door Handle Replacement
Wat je nodig hebt
  1. 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: stap 1, afbeelding 1 van 3 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: stap 1, afbeelding 2 van 3 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: stap 1, afbeelding 3 van 3
    • Open the appropriate side door of your vehicle that requires a door handle replacement.
    • Locate the tab on the panel behind the door handle.
    • Use a flat-head screwdriver (1 x 3 mm) to move the tab to the right and slightly pull the panel out.
  2. 2003-2007 Honda Accord Interior Door Handle Replacement: stap 2, afbeelding 1 van 3 2003-2007 Honda Accord Interior Door Handle Replacement: stap 2, afbeelding 2 van 3 2003-2007 Honda Accord Interior Door Handle Replacement: stap 2, afbeelding 3 van 3
    • Locate two (2) Phillips head screws behind the door handle.
    • Remove the two Phillips head screws (1.6 x 1.3 x 10.16 mm) using a Phillips head screwdriver (1 x 3 mm).
  3. 2003-2007 Honda Accord Interior Door Handle Replacement: stap 3, afbeelding 1 van 3 2003-2007 Honda Accord Interior Door Handle Replacement: stap 3, afbeelding 2 van 3 2003-2007 Honda Accord Interior Door Handle Replacement: stap 3, afbeelding 3 van 3
    • The first image shows the approximate location of 3 tabs behind the door handle assembly. Knowing the location of tabs is useful when attempting to release assembly.
    • Using your left hand, pull the assembly to the left to reveal the tab on the right. While pulling on the assembly, use a flat-head screwdriver (1 x 3 mm) to press the tab inward to release.
    • Once the tab on the right is released, a slight pull of assembly will release it from the door.
  4. 2003-2007 Honda Accord Interior Door Handle Replacement: stap 4, afbeelding 1 van 3 2003-2007 Honda Accord Interior Door Handle Replacement: stap 4, afbeelding 2 van 3 2003-2007 Honda Accord Interior Door Handle Replacement: stap 4, afbeelding 3 van 3
    • Rotate the door handle assembly for ease of access to clips
    • Locate the first clip holding the door cable.
    • Rotate the clip clockwise to unlock the cable.
    • Once unlocked, pull the cable end from the holder.
  5. 2003-2007 Honda Accord Interior Door Handle Replacement: stap 5, afbeelding 1 van 2 2003-2007 Honda Accord Interior Door Handle Replacement: stap 5, afbeelding 2 van 2
    • Locate the second clip holding the door cable.
    • Using a flat-head screwdriver (1 x 3 mm), release the clip.
    • Once the cable is released, the assembly is free to remove.
Conclusie
To install your new door handle assembly, follow these instructions in reverse order.
Additional tips: For step 5, the clip will be pushed back into the clip holder. For step 4, replace the cable and rotate the clip clockwise.
Erik amundsen
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 78
