Ga door naar hoofdinhoud
2003-2007 Honda Accord Front Brake Pads Replacement
Wat je nodig hebt
  1. 2003-2007 Honda Accord Front Brake Pads Replacement, Using a Floor Jack: stap 1, afbeelding 1 van 2 2003-2007 Honda Accord Front Brake Pads Replacement, Using a Floor Jack: stap 1, afbeelding 2 van 2
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
    Just for understanding: the crossmember runs from the legt fender to right fender, or am I wrong?
    VauWeh - Antwoord
    ( I mean left fender)
    VauWeh - Antwoord
    Correct-o-mungo!!
    Kevin R Brown - Antwoord
  2. 2003-2007 Honda Accord Front Brake Pads Replacement, Using floor jack to lift car.: stap 2, afbeelding 1 van 1
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 3, afbeelding 1 van 1
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 4, afbeelding 1 van 1
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
    Floor jack is not designed to hold the weight. In case the jack stand fails, put jack stand under the car if possible.
    BBMonster - Antwoord
  5. 2003-2007 Honda Accord Front Brake Pads Replacement, Front Brake Pads: stap 5, afbeelding 1 van 1
    • Once car is raised, remove the lug nuts on one of the front tires with the 3/4'' socket.
    Loosen the lug nuts before jacking up the car!
    Dipen Chauhan - Antwoord
    Use a 19mm socket
    Jerry Crooks - Antwoord
  6. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 6, afbeelding 1 van 3 2003-2007 Honda Accord Front Brake Pads Replacement: stap 6, afbeelding 2 van 3 2003-2007 Honda Accord Front Brake Pads Replacement: stap 6, afbeelding 3 van 3
    • Remove the wheel and tire off the wheel studs, and place it aside.
    • This exposes the caliper (shown in rectangle) and rotor (shown in circle).
  7. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 7, afbeelding 1 van 3 2003-2007 Honda Accord Front Brake Pads Replacement: stap 7, afbeelding 2 van 3 2003-2007 Honda Accord Front Brake Pads Replacement: stap 7, afbeelding 3 van 3
    • Identify the two mounting bolts on the rear of the caliper.
    • Using a 12 mm wrench or socket, remove the two caliper mounting bolts.
    • Alternatively, you may remove only the bottom mounting bolt and, using the top bolt as a hinge, rotate the caliper up and away from the rotor to access the brake pads. If you do this, skip the next step.
    I found it’s easier to remove only the bottom mounting bolt then lift the caliper to remove the brake pads. The caliper remained in up position and because it was attached it posed no risk of falling off the rotor and damaging the brake line.
    Laura Bernal - Antwoord
  8. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 8, afbeelding 1 van 3 2003-2007 Honda Accord Front Brake Pads Replacement: stap 8, afbeelding 2 van 3 2003-2007 Honda Accord Front Brake Pads Replacement: stap 8, afbeelding 3 van 3
    • Slide the caliper off and rest it on the top of the rotor.
    • Do not let the caliper hang freely because the brake lines may stretch and weaken.
  9. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 9, afbeelding 1 van 2 2003-2007 Honda Accord Front Brake Pads Replacement: stap 9, afbeelding 2 van 2
    • Pull the two old brake pads out of both the front and rear of the pad bracket.
  10. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 10, afbeelding 1 van 1
    • Inspect the brake pad wear sensor on the old brake pad. The sensor is a metallic tab attached to the brake pad. When the brake pads wear down too much, the metallic tab contacts the rotor and makes a screeching sound.
  11. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 11, afbeelding 1 van 1
    • Place the new brake pads into the bracket. Make sure that the new pads are secure.
  12. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 12, afbeelding 1 van 1
    • The new brake pads are thicker than the old pads. Because of this, the caliper piston protrudes too far out to allow enough clearance for the caliper to be placed over the new pads. You will need to manually retract the caliper piston.
    • To do this, place an old brake pad over the caliper piston.
  13. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 13, afbeelding 1 van 2 2003-2007 Honda Accord Front Brake Pads Replacement: stap 13, afbeelding 2 van 2
    • Place one end of the c-clamp jaw over the old pad. Place the other end of the jaw on the rear of the caliper. Tighten the c-clamp to push the piston back into the caliper.
    • This will push oil back into the brake reservoir, which could overflow. This can be wasteful, messy, and damage your car's paint job. Make sure the reservoir isn't topped off. It is also a good idea to remove the cap from the reservoir before retracting the piston. The reservoir is located under the hood and should be clearly labeled.
  14. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 14, afbeelding 1 van 2 2003-2007 Honda Accord Front Brake Pads Replacement: stap 14, afbeelding 2 van 2
    • Slide the caliper over the brake pad bracket with the new brake pads.
    • If you removed the cap from the brake fluid reservoir replace it as soon as the brake caliper piston has been retracted. Do not leave the cap off any longer than absolutely necessary.
  15. 2003-2007 Honda Accord Front Brake Pads Replacement: stap 15, afbeelding 1 van 1
    • To reassemble the wheel assembly. Follow the Steps 1-7 in reverse order.
    • The caliper mounting bolts and the lug nuts must be tightened to the correct torque value, using a torque wrench. The values may differ depending on your car's configuration and options, but are typically listed as:
    • Caliper bolts: 54 ft lbs
    • Lug nuts: 80 ft lbs
    • Remove the jack stand. Then lower and remove the floor jack.
    • CAUTION! : Before driving the car, pump the brake pedal several times in order to push the caliper piston back against the brake pads. If this step is not performed, the car may not brake reliably when first driven. For your safety, this step is essential.
Eindstreep
26 andere personen hebben deze handleiding voltooid.
Shaun MacDonald
2.558 Reputatie
8 handleidingen geschreven
Cal Poly, Team 24-27, Regan Fall 2012 Lid van Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Leden
22 handleidingen geschreven
Één opmerking
Safety tip - before lifting the car up with the jack, break loss the lug nuts as in step 5, break lose means to get them started but they are still snug. Why - This way you don't have to crank with strength when the car is on the stands and possibly knock it off the stands.
mike whitaker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 73
Afgelopen 30 dagen: 258
Altijd: 82,587
