Ga door naar hoofdinhoud
2003-2007 Honda Accord Battery Replacement
Wat je nodig hebt
  1. 2003-2007 Honda Accord Battery Replacement, Battery: stap 1, afbeelding 1 van 2 2003-2007 Honda Accord Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the latch to open your hood, normally located by your left foot when sitting in the driver's seat.
    • After lifting the latch, open your hood and securely hold it up.
  2. 2003-2007 Honda Accord Battery Replacement: stap 2, afbeelding 1 van 3 2003-2007 Honda Accord Battery Replacement: stap 2, afbeelding 2 van 3 2003-2007 Honda Accord Battery Replacement: stap 2, afbeelding 3 van 3
    • You will lose your radio station presets and clock time if you do not use a Memory Saver. One will NOT be used in this guide.
    • The battery is located on the front driver's side of the vehicle.
    • Begin using your ratchet to loosen and remove the negative (black) cable from the terminal.
    • You can use a rag or towel to cover the cable in order to prevent a short.
  3. 2003-2007 Honda Accord Battery Replacement: stap 3, afbeelding 1 van 2 2003-2007 Honda Accord Battery Replacement: stap 3, afbeelding 2 van 2
    • Loosen and remove the positive (Red) cable from the terminal.
  4. 2003-2007 Honda Accord Battery Replacement: stap 4, afbeelding 1 van 3 2003-2007 Honda Accord Battery Replacement: stap 4, afbeelding 2 van 3 2003-2007 Honda Accord Battery Replacement: stap 4, afbeelding 3 van 3
    • Remove the cross-bar that holds the battery in place by loosening both bolts.
    • Lift out the bracket.
  5. 2003-2007 Honda Accord Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery by lifting it straight up and out.
    • Avoid tilting the battery in order to prevent an acid spill.
  6. 2003-2007 Honda Accord Battery Replacement: stap 6, afbeelding 1 van 1
    • Replace with a new battery.
    • Secure the battery cover back in place.
  7. 2003-2007 Honda Accord Battery Replacement: stap 7, afbeelding 1 van 1
    • Place the cross-bar back in place.
    • When placing the cross-bar back in, make sure the bars are properly hooked into place.
  8. 2003-2007 Honda Accord Battery Replacement: stap 8, afbeelding 1 van 3 2003-2007 Honda Accord Battery Replacement: stap 8, afbeelding 2 van 3 2003-2007 Honda Accord Battery Replacement: stap 8, afbeelding 3 van 3
    • Repeat the steps in reverse order to properly secure battery.
  9. 2003-2007 Honda Accord Battery Replacement: stap 9, afbeelding 1 van 1
    • Start your car in order to make sure all of your electronic components are working properly.
Conclusie
To reassemble the battery, follow these instructions in reverse order.
10 andere personen hebben deze handleiding voltooid.
Johnny Hernandez
371 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-4, Green Fall 2015 Lid van Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 Leden
4 handleidingen geschreven
3 opmerkingen
I believe you can remove the battery while the engine is running, one way to avoid radio reset. BUT the replacement procedure must be done FASTT! (I've done it twice without an issue, attempt at your own risk)
llcoolj0n - Antwoord
A 9 Volt battery plugged into the Cigarette Lighter Socket will save the SETTINGS; just keep it handy in the glove box because those batteries eventually fail.
jhgrossman - Antwoord
I changed my battery and the horn won’t shut off. What does that mean
Trenton Jones - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 215
Altijd: 62,543
