Ga door naar hoofdinhoud
2003-2008 Toyota Corolla Headlight Bulb Replacement
Wat je nodig hebt
  1. 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 1 van 2 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 2 van 2
    • Locate the handle to open the hood. It will be on the driver side of the car to the left.
    • Pull up on the handle and the hood should pop open a small amount.
  2. 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 2, afbeelding 1 van 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 2, afbeelding 2 van 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 2, afbeelding 3 van 3
    • Reach under the hood in the front where there is a small notch and pull the latch up. This will allow the hood to open all the way.
    • Locate the prop and insert it into the hole in the hood.
  3. 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 3, afbeelding 1 van 1
    • Locate the bulb. It will be in the front and to the side. Start with the side opposite from the battery.
  4. 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 4, afbeelding 1 van 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 4, afbeelding 2 van 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 4, afbeelding 3 van 3
    • Twist assembly 45 degrees counter clockwise and pull straight out.
    • Be careful not to touch the glass on the new bulb. The oils from your hand could cause premature bulb failure.
  5. 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 5, afbeelding 1 van 2 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 5, afbeelding 2 van 2
    • Lift up on the latch and pull. The bulb will come free from the wires.
  6. 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 6, afbeelding 1 van 2 2003-2008 Toyota Corolla Headlight Bulb Replacement: stap 6, afbeelding 2 van 2
    • Locate the other bulb, and repeat steps 3-5 to remove it.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Frederick Henderson
416 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-4, Green Fall 2015 Lid van Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Leden
4 handleidingen geschreven
Één opmerking
https://youtu.be/GHezj9nmbxE
Change headlight on your corolla in under one minute. So easy.
baxta777 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 105
Afgelopen 30 dagen: 407
Altijd: 92,640
