Ga door naar hoofdinhoud
2003-2008 Toyota Corolla Finding the Fuse Box
Wat je nodig hebt
  1. 2003-2008 Toyota Corolla Finding the Fuse Box, 2003-2008 Toyota Corolla Finding the Fuse Box: stap 1, afbeelding 1 van 1
    • You will find the fuse box behind the coin pocket at the left side (not for uk models). Open the coin pocket and then pull it off. You will see fuses in the hole. It is a black covered square box inside - usually press the sides and the cover should pop off. For UK, passenger side, open the glove box, pull it off clip hinges, box is behind.
    What is the name of that plastic cover?? I cannot find replacement!
    Marina - Antwoord
    Disculpa amigo sele fue la corriente positiva al relex del electro y no se donde está ubicado el fusible
    Jimmy - Antwoord
  2. 2003-2008 Toyota Corolla Finding the Fuse Box: stap 2, afbeelding 1 van 1
    • After taking the box cover you will be able to change the fuse. In my case it was the number 38 (in the fielder model the position can change). For more details see the User's Manual for fuse diagrams.
    What location is the radio fuse
    Danny Cruz - Antwoord
    Yea cant get the cover off or any pic of the cove saw one video showing a quick clip on the left side and it pops of but mine isnt like that
    Bob Kelly - Antwoord
    What is "fielder" model mentioned in post ??
    BobbyB - Antwoord
    Bonjour je n’ai plus le manuelle de mon véhicule quel fusible est liés pour les vitre car elles sont électriques je souhaites les changer car elles ne fonctionnent plus
    Serge Bona - Antwoord
Conclusie
24 andere personen hebben deze handleiding voltooid.
Jesse Teixeira Silva
649 Reputatie
1 Handleiding geschreven
27 opmerkingen
Will this work for Toyota Rukus as we have on our website http://www.toyotarukusclub.com too?
James Wools - Antwoord
1. This doesn't actually show anything about where it is or how you got to it.
2. The only "black box" in any of your photos is the dead pedal, which is definitely not where the fuses are.
How is this page the top result for toyota corolla fuse box in Google?
Dinksmack - Antwoord
Guys, the 2004 Corolla Japan made, the internal fuse panel does not locate behind the coins tray.
you must lay down on the floor of the car on driver side (hard due to less room), look up under the dash board you will find very samll black plastic cover (1 inch wide and 4 inches long), you may need a flash light, open this cover by press the letch which is located only your left hand side by laying down on the ground.
This is a verse thing ever I saw in Toyota, this fuse pannel is very hard to work, even the fuse diagram/location mentioned behind the cover is wrong as well. I just need to replace the power window fuse which was mentioned on the cover location at a wrong place, I found the menual was help full to find the location for the correct fuse only.
Hope it will help full and sorry for the typo if any.
Shahbaz -
Dink. I’m so glad someone said it. I was just about to start yelling at my monitor.
gallain -
I finally found a forum that helped me fixed my ac not blowing hot air issue. I thought at first my compressor went out, the relay was burned from under the hood and I replaced that with no success, I even used the horn relay with no success. I tested the wiring and looked at every freakin thing. I too did not find the interior fuse box behind the coin box. It was there but way the f**k under the dashboard as the previous comment mentioned. I finally found the #24 fuse 10 Amp was burned up. I replaced it and that wonderful cold air came out once again. I almost took this car to a mechanic and I knew it would cost a pretty penny. Hope this helps the next fellow.
crgarcia68 - Antwoord
Also, check that you haven't accidentally pressed the "Child Window Lock" button on the driver's side accidentally. As this will also prevent the other windows from operating. :)
brd561 - Antwoord
How do you get to the Instrument Panel J/B? I need to replace my circuit opening relay.
chelsear12 - Antwoord
Stupid answer that doesn't answer the question because it doesn't show where the fuse box is at
Hal Hannon - Antwoord
Shahbaz nailed it. I replaced the fuse for radio, clock, cig just 5 minutes ago. There were extra fuses in fuse box next to battery. But to find other fuse box just lay on floor where pedals are and look up. Find small long black cover and pop it off. The black cover conveniently labels what each fuse is for. Mine was labeled 'Cig'.
Tom DePew - Antwoord
Where is the fuse box/fuse that control the rear indicator lights
Frank Johnson - Antwoord
Where do I find the fuse box/fuse that control the rear indicator light on my 2003 Toyota Corolla S car?
Found it, thanks! It is way far up under the steering wheel, so I had to lay on my back with my feet out the door and wiggle up under the steering wheel to locate it! I found the correct fuse after some testing and now my power windows work again.
Danielle Collins - Antwoord
I have a 2004 toyota caldina azt ac stop working cig and radio where is the fuse box located.
Recardo Wilkins - Antwoord
I have a 2003 Toyota Corolla. The “cigarette Lighter” won’t work. I use this for the GPS. It may be called a “axillary power supply”
Why Toyota would be so stupid to put the fuse box in such a hard to reach place and make it so hard to change a fuse is beyond me. All they are doing is guiding me to other car makers. Before I buy a new car, I will look for things like this. If Toyota were wise, they would make things easier like they did in the older days when they really cared about people buying their cars, and not having to go through so much trouble for a simple thing like changing a fuse. Shamed on you Toyota.
jim neighbors - Antwoord
Where is the interior fuse box, for cig fuse, on uk model of corolla?
Tracey Aldred - Antwoord
Hello where is the fuse for vvti corolla radiator fan under the dash located ?
Ruben De Villiers - Antwoord
Just a little off topic. I am sitting in the Toyota dealership right now getting my 2003 Corolla airbag recall replaced. My horn does not work I asked them to see if anything is wrong with it under the steering wheel when they change the airbag. They wanted $54 just to look at it. WTF I can't wait to get out of here in probably go to an auto parts store and do it myself.
Ryan Fulkerson - Antwoord
Like seriously people are @%^$$@$#. They seriously wanted to charge me $54 to look at something they were already looking at give me the steering wheel isn't that big.
Ryan Fulkerson -
Hi could you tell me where the airbag (SRS) fuse is located on a 2003 corolla t sport please cheers.
pyates259 - Antwoord
Airbag systems have no fuse!
If you want to deactivate one, please go to a service station. Its dangerous, to work at this systems without good knowledge.
Claus Gärtner -
Hi, i have an 03 toyota Corolla le.
It was driving fine, got in the car to go to work no power. Changed battery, no power.
I replaced battery terminals, still no power.
What is going on with my car?
KSE inc - Antwoord
On a RH drive 2006 Toyota Runx (similar to a Corolla) pull out the Glove box on the LHS of the car .Its horizontal near the top of the hole where the glove box used to be.
Ric Stacey - Antwoord
Jesse T. Silva’s description of the fuse box location is wrong, and to get at it is definitely not “very easy”. Its location was correctly explained by Shahbaz above. To get at it takes a contortionist and it seems as if Toyota made it difficult to reach on purpose. The usually minor task of replacing a fuse will now have to be done by a seasoned Toyota mechanic charging unreasonable fees.
helmut koch - Antwoord
Por favor perdí el aditamento metalico para el cierre de la tapa de la caja de los fusibles del corolla del 2006, es la tapa que se encuentra en la parte inferior izquierda del timón. Favor enviar foto para ver si puedo hacerla. Saludos
Icael Bilbao - Antwoord
Good day ,please l have 2008 Toyota corolla tumb start but ignition do fail at times l will need to let it cool like one to two hours before it will see the ignition sensor . have done all what l can do but the case remain the same. Rewire have done their part, they have tested the key fob is working perfectly. Please what could be the problem. Anyone can reach at me @ emmanueladedejiabayo@gmail.com
Adedeji Emmanuel - Antwoord
Bonjour j'ai une lampe de frein à main et ABS qui s'allume toujours
zennir_lazhar - Antwoord
Where is the fuse box in a 2013 Honda Fit (base model)?
Paula Thompson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 56
Afgelopen 7 dagen: 530
Afgelopen 30 dagen: 2,344
Altijd: 339,123
