Ga door naar hoofdinhoud
2003-2008 Pontiac Vibe Tail Light Bulb Replacement
Wat je nodig hebt
  1. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement, Tail Light Bulb: stap 1, afbeelding 1 van 1
    • Begin by opening up the rear hatch door by reaching under the "Pontiac" logo and pressing on the rear hatch door button.
    • Pull on the door from the same location to open the rear hatch.
  2. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 2, afbeelding 1 van 1
    • Locate the tail light access doors on the left and right sides in the trunk compartment.
  3. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 3, afbeelding 1 van 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 3, afbeelding 2 van 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 3, afbeelding 3 van 3
    • Press in on the opening tab and pull on the door to release the two clips on the left side.
    • Completely remove the access door and set it off to the side.
  4. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 4, afbeelding 1 van 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 4, afbeelding 2 van 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 4, afbeelding 3 van 3
    • Inside of the compartment, there is the tail light bulb at the top, and the turn signal bulb on the bottom.
    • Reach inside with your hand and grab onto the tail light bulb socket. Rotate it counter-clockwise to unseat it from the tail light and remove the socket.
  5. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 5, afbeelding 1 van 2 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: stap 5, afbeelding 2 van 2
    • Hold onto the bulb socket and gently pull out the bulb with your other hand.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Craig Lloyd
35.368 Reputatie
82 handleidingen geschreven
2 opmerkingen
How do I replace the 3rd brake light?
Jennifer Trissell - Antwoord
What about the 3rd bulb
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 85
Altijd: 9,225
