Ga door naar hoofdinhoud
2003-2008 Honda Pilot Battery Replacement
Wat je nodig hebt
  1. 2003-2008 Honda Pilot Battery Replacement, Battery: stap 1, afbeelding 1 van 3 2003-2008 Honda Pilot Battery Replacement, Battery: stap 1, afbeelding 2 van 3 2003-2008 Honda Pilot Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • On the inside of the driver’s side door is a latch the pops open the hood of the car. Pull the latch.
    • Underneath the hood is another latch to open the hood. Pull this latch and lift up on the hood of the car, revealing the engine.
    • Use the arm to keep the hood of the car propped open.
  2. 2003-2008 Honda Pilot Battery Replacement: stap 2, afbeelding 1 van 2 2003-2008 Honda Pilot Battery Replacement: stap 2, afbeelding 2 van 2
    • The car battery is placed on the right side, under the hood.
  3. 2003-2008 Honda Pilot Battery Replacement: stap 3, afbeelding 1 van 3 2003-2008 Honda Pilot Battery Replacement: stap 3, afbeelding 2 van 3 2003-2008 Honda Pilot Battery Replacement: stap 3, afbeelding 3 van 3
    • Use the pliers to loosen the negative (-) cable from the battery. Then loosen the positive (+) cable from the battery.
    • Gently remove the battery, and place it aside.
  4. 2003-2008 Honda Pilot Battery Replacement: stap 4, afbeelding 1 van 2 2003-2008 Honda Pilot Battery Replacement: stap 4, afbeelding 2 van 2
    • Take your new battery and place it where the old one was. Secure it into place with the plate, connect the negative (-) cable to battery. Then connect the positive (+) cable to battery.
Conclusie
There are several places to take your old car battery to be recycled. One of the most convenient places to take you battery to be recycle is AutoZone. Simply place your dead car battery in a plastic bag and drop it off for AutoZone to recycle – free of charge
Mitchell Baker
209 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 62
Altijd: 5,831
