Inleiding
This is a relatively easy job, the fastening bolts are all located on top of the engine. The coilpack connectors are easy to disconnect without damaging anything, and the spark plugs themselves are not difficult to replace.
Note: This service requires that the battery is disconnected, meaning that the factory radio will require its code to be reentered. Do not perform this service without the code, a dealer would have to re-enable the stereo's functions
Wat je nodig hebt
Pull hood latch release, located on the base of the A-Pillar.
Pull up on the release lever between the hood and grille, it is located on the left.
Lift hood and engage the hood prop rod inside the provided notch hole on the edge of the hood.
Pull up on coilpack lightly, it should release easily from the spark plug below.
Using your thumb and forefinger, grasp the connector, pushing down the latch with your thumb.
Wiggle and pull the connector off of the coilpack, it will have some resistance.
If the connector does not release, try pushing connector in, then pushing the latch and pulling on the connector.
Note: Do not pull by the wires.
Reinstall the coilpack 3/4 of the way into the hole, then push on the electrical connector until it clicks.
Push the coilpack down the rest of the way into the spark plug well, you should feel a slight click as the coilpack connects to the contact of the spark plug
Repeat these same steps for the remaining 3 coilpacks.
This is a great job to do to save some money, its involved enough to be entertaining but not enough to be scary.
9 andere personen hebben deze handleiding voltooid.
4 opmerkingen
I torqued the spark plugs to 13 ft lbs.
You put quite a bit of effort into creating this extremely helpful guide. I hope others appreciate all of your hard work. Thank you so much for doing a terrific job and making the world a better place.
Thank you for this! Much appreciated- saved me so much money and learned how to do it myself :)
Cheers!
Thorough and complete walk-thru on this task. Well done!
