Ga door naar hoofdinhoud
2002-2006 Acura Integra Hatch Strut Replacement
Wat je nodig hebt
  1. 2002-2006 Acura Integra Hatch Strut Replacement, Hatch Strut: stap 1, afbeelding 1 van 1
  2. 2002-2006 Acura Integra Hatch Strut Replacement: stap 2, afbeelding 1 van 3 2002-2006 Acura Integra Hatch Strut Replacement: stap 2, afbeelding 2 van 3 2002-2006 Acura Integra Hatch Strut Replacement: stap 2, afbeelding 3 van 3
    • Go to the rear of the vehicle.
    • Pull up on the trunk handle to lift open the trunk.
  3. 2002-2006 Acura Integra Hatch Strut Replacement: stap 3, afbeelding 1 van 3 2002-2006 Acura Integra Hatch Strut Replacement: stap 3, afbeelding 2 van 3 2002-2006 Acura Integra Hatch Strut Replacement: stap 3, afbeelding 3 van 3
    • Prop open hatch or have someone help support the hatch weight.
    • Remove the upper ball mount.
    • Turn the upper ball mount counterclockwise with a 12mm wrench.
    • It will pop off when it's completely unscrewed.
  4. 2002-2006 Acura Integra Hatch Strut Replacement: stap 4, afbeelding 1 van 2 2002-2006 Acura Integra Hatch Strut Replacement: stap 4, afbeelding 2 van 2
    • Remove the lower ball mount.
    • Turn the lower ball mount counterclockwise with a 12mm wrench.
  5. 2002-2006 Acura Integra Hatch Strut Replacement: stap 5, afbeelding 1 van 3 2002-2006 Acura Integra Hatch Strut Replacement: stap 5, afbeelding 2 van 3 2002-2006 Acura Integra Hatch Strut Replacement: stap 5, afbeelding 3 van 3
    • Place a washer on the new upper ball mount.
    • Turn it clockwise to hand tighten the new upper ball mount.
    • Turn it clockwise with the crescent wrench to finish tightening.
  6. 2002-2006 Acura Integra Hatch Strut Replacement: stap 6, afbeelding 1 van 2 2002-2006 Acura Integra Hatch Strut Replacement: stap 6, afbeelding 2 van 2
    • Place a washer on the new lower ball mount.
    • Turn it clockwise to hand tighten the new lower ball mount.
    • Turn it clockwise with a crescent wrench to finish tightening the new lower ball mount.
  7. 2002-2006 Acura Integra Hatch Strut Replacement: stap 7, afbeelding 1 van 2 2002-2006 Acura Integra Hatch Strut Replacement: stap 7, afbeelding 2 van 2
    • Place a lower hatch strut socket over the new lower ball mount.
    • Push it firmly onto the new lower ball mount. It will pop on easily.
  8. 2002-2006 Acura Integra Hatch Strut Replacement: stap 8, afbeelding 1 van 1
    • Place the upper hatch strut socket over the new upper ball mount.
    • Press it firmly onto the new upper ball mount. It will pop on easily.
Conclusie
Michael Hagar
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 691
