Ga door naar hoofdinhoud
2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement
Wat je nodig hebt
  1. 2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement, Transfer Case Oil: stap 1, afbeelding 1 van 2 2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement, Transfer Case Oil: stap 1, afbeelding 2 van 2
    • Locate the transfer case in the center of the undercarriage of your Dodge. Position yourself under the drivers side seat and look upwards toward the front left tire.
    • Locate the fill plug on the transfer case. and remove it using the 10 mm hex driver. The fill plug is the upper steel plug just to the left of the rear output of the transfer case.
    • No oil will drain after the filler plug is removed.
  2. 2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement: stap 2, afbeelding 1 van 2 2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement: stap 2, afbeelding 2 van 2
    • Set the drain pan underneath the transfer case. Make sure that the drain pan has enough room for about 2 quarts of oil.
    • Locate the drain plug just left and under the filler plug.
    • As soon as the filler plug is removed the Transfer case oil will begin to drain. Take caution when removing the drain plug.
    • Due to limited resources, the transfer case oil was not actually changed for this guide.
    • While applying pressure towards the front of the car unscrew the drain plug with the 10mm Hex. Once you feel that the Plug is fully unthreaded quickly pull the plug away allowing the oil to drain.
    • The oil will take upwards of 5 minutes to completely drain.
  3. 2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement: stap 3, afbeelding 1 van 2 2002-2008 Dodge Ram 1500 Transfer Case Oil Replacement: stap 3, afbeelding 2 van 2
    • Tighten the drain plug using the 10mm hex.
    • Fill the transfer case with the ATF oil using the vacuum oil pump. When the case is full, oil will begin dripping out of the fill hole.
    • Insert and tighten the filler plug using the 10 mm hex.
    • Be careful to line up each plug carefully to prevent cross-threading. Do not overtighten the plugs, as overtightening may cause the threads to strip.
    • Due to limited resources the transfer case oil was not actually changed.
Conclusie
To dispose of your used transfer case oil, take the oil drain pan to an automotive parts store. Most automotive parts stores have a recycling program for used oil. Do not dump your oil down any drains or sinks.
5 andere personen hebben deze handleiding voltooid.
Michael Saggese
1.021 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-24, Amido Fall 2012 Lid van Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Leden
11 handleidingen geschreven
7 opmerkingen
If i put to much oil in it will it hurt the transfer case?
Timothy Forbus - Antwoord
No, not unless you go crazy with overfilling it. Say you put in an extra pint or so... No harm will be done. Truthfully, it's pretty difficult to severely overfill a transfer case since the filler/oil level hole is located in the side of the casing. Worst it could do is blow some oil out of the breather (vent) tube that's located at/near the top of the transfer case. When refilling your transfer case, be sure to use ATF that is Dexron II, Dexron III, or Dexron IV. I believe the actual recommended spec is to use Dexron III. Another thing to note is that some guys like to use a full synthetic of 75W-90 gear oil. Although not recommended by Chrysler/Dodge, it has been reported to work fine with no complications. Personally, I use Dexron III.
Turbo Diesel -
This transmission uses ATF+4 you cannot put Dexron III in it.
bigtop69 - Antwoord
Im having issues with a yellow fluid leaking from the rear of my 2012 1500 dodge ram. Its a pretty clean looking fluid with no metal or dirt in it..No active leaks that I can spot to narrow it down though..All engine fluids, transmission, radiator, etc fluid are fine and are not the same color..Could transfer case or rear differential fluid be that color?
Terry - Antwoord
Probably diff fluid. Does it smell kinda like the worst smell you've ever smelled?
andrew.holloway1776 -
he thanks for the info !!
PIZZA-MAN-3256 - Antwoord
By the way, the recommended transfer case fluid on Dodge Rams 1500 is the same as the automatic transmission fluid wich is ATF+4.
ben-gi-8 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 162
Altijd: 43,279
