Ga door naar hoofdinhoud
2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement
Wat je nodig hebt
  1. 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement, Stereo Head Unit: stap 1, afbeelding 1 van 2 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement, Stereo Head Unit: stap 1, afbeelding 2 van 2
    • Fold up your center console and take a seat with a good view of your stereo.
    • Locate the screw in the bottom right hand side of the console, just above the coat hanger hook.
    • When removing the screw, be careful to prevent the screw from falling into the console. Use your finger to clamp it against the screwdriver to ensure it does not slip off.
    • Remove the 12mm long #2 Phillips screw with a #2 screwdriver.
  2. 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 2, afbeelding 1 van 3 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 2, afbeelding 2 van 3 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 2, afbeelding 3 van 3
    • Lower the cup holder and trash receptacle to allow better access to the bottom lip of the console trim.
    • Be careful when popping off the console trim. Delicate wires controlling the AC and cigarette lighter are attached to the front face. A forceful pull may break the connections.
    • Grasp the bottom right hand corner of the console trim and slowly pull toward you. Gradually increase your force until the you feel the right side clips pop off.
    • Repeat again on the bottom left side of the clips to fully remove the anchoring clips.
    • Once the clips are popped out, slowly lower the face plate and lay it down, supported by the wires coming out the back side.
  3. 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 3, afbeelding 1 van 3 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 3, afbeelding 2 van 3 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 3, afbeelding 3 van 3
    • Note the locations of the wires and where they are attached. If you happen to dislodge the wires during removal you will be able to re-attach them upon re-installation.
    • Locate and remove the four anchoring 12mm long #2 Phillips screws for the head unit using the #2 screwdriver.
    • It is now safe to pull out the head unit. Support it in one hand to reduce tension in the cables.
  4. 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 4, afbeelding 1 van 3 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 4, afbeelding 2 van 3 2002-2008 Dodge Ram 1500 Stereo Head Unit Replacement: stap 4, afbeelding 3 van 3
    • Support the unit in one hand to remove tension from the wiring harness.
    • Pinch the multi-wire connector and pull away from the unit to disconnect.
    • Note the location and orientation of your RCA cables to aid in re-installation. It is usually most useful to take a picture of the cables in place before removal.
    • Remove the 4 RCA cords by simply pulling them out of each jack.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Ken
548 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-24, Amido Fall 2012 Lid van Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Leden
11 handleidingen geschreven
7 opmerkingen
That does not look like the dash on my 2007 Ram 1500 SLT Quad Cab.
James - Antwoord
nor does it look like the dash of a 2008 RAM 1500 SLT Quad Cab either
Don - Antwoord
This should be listed for Ram 1500 2002-2005 years. The 2500/3500 kept this dash longer, until 2006.
Kelly Spongberg - Antwoord
It looks exactly like my 2002 Dodge Ram 1500 SLT Quad Cab 4.7 Liter V8.
Xavier Sepeda - Antwoord
I have a radio that turns on, has power because the blue light turns on, but nothing comes on the screen, there is no sound and nothing will play. Any ideas?
Phillip Barrett - Antwoord
It is exactly like my 2004 Quad cab ST and the instructions were impeccable.
Kevin Maxson - Antwoord
Thanks! Not even 5 minutes of time from beginning to end.
Scott Morse - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 105
Altijd: 35,223
