Ga door naar hoofdinhoud
2002-2008 Dodge Ram 1500 Headlight Assembly Replacement
Wat je nodig hebt
  1. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: stap 1, afbeelding 1 van 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: stap 1, afbeelding 2 van 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: stap 1, afbeelding 3 van 3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 2, afbeelding 1 van 1
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 3, afbeelding 1 van 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 3, afbeelding 2 van 3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 3, afbeelding 3 van 3
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 4, afbeelding 1 van 2 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 4, afbeelding 2 van 2
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
    Is there any kind of plastic screw/bolt keeping the assembly in? I removed all the bolts listed and the assembly still would not come out. What am I missing?
    lpkzach92 - Antwoord
  5. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 5, afbeelding 1 van 2 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: stap 5, afbeelding 2 van 2
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Michael Saggese
1.021 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-24, Amido Fall 2012 Lid van Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Leden
11 handleidingen geschreven
9 opmerkingen
Don't forget to explain that there is a third bolt hidden behind the wheel frame under a rubber grommet Other than that hidden bolt. I had both headlights out and replaced in 30 mins.
sreilly623 - Antwoord
yep. found it. with all humbleness i ask, how do i get it? i am not a car guy. sorry. dont revoke man card.
theycallmemrc -
What wrench size for the bolt in the fender?
Kurt Smith - Antwoord
10mm for all three of them
Thomas Murray - Antwoord
I have a question are all 3 bolts the same I lost the one that goes underneath the headlight between the bumper will the other two one or the other still work until I can get replacement
lgweaver80 - Antwoord
they all three are the same use one under headlight now and one on the top, replace the bottom left when you can
five0runnr_2000 - Antwoord
This is not the same for an 06 model….
Glen Corneilsen - Antwoord
Does anyone know where I can buy that plastic socket that the lower back knob “plugs” in to when putting the headlight back into place? My plastic socket broke and I have no idea where I can buy another one (or two).
Jace Alvarez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 135
Altijd: 52,825
